13 Replies Latest reply on Feb 5, 2008 6:55 PM by Al Ferrari
    Needed: Recommendation for lower-price color inkjet with postscript
      I'd like to keep my total budget for an inkjet printer to under $750 if possible. What are my options, good folks? I am a graphic designer, so I need to be able to proof clean vectors and very good color reproduction. 13 x 19 output would be optimal. I'm thinking the Epson 1400 plus PowerRIP. Any other options out there?
        • 1. Re: Needed: Recommendation for lower-price color inkjet with postscript
          Lou Dina Level 3
          Daniel,
          I did a lot of proofing of jobs destined for press, and never used a RIP. If you print from Photoshop, Illustrator or InDesign, you probably don't need a RIP as long as you have good printer profiles. Vectors print just fine as long as you have good resolution. I used to do all my proofs on an Epson 2200, and they matched my printer's inkjet proofs almost perfectly. An Epson 2400 would definitely do the job just fine. Many printers use Epson printers for their contract proofs anyway. I tried PowerRIP and wasn't particularly impressed with it. Most RIPs (especially inexpensive ones) are a pain in the butt. Use the driver with a good custom profile and you should be in good shape. If you select a suitable proofing paper, with characteristics that are similar to what your printer uses, you should get a great match. Most printers will not use your proof as a basis for a contract anyway, and will insist on using their own proof to match against. I used to provide a proof to show them what I wanted the job to look like. As it turned out, I had great profiles for my printer, and I had their proofer profile, so they were nearly the same anyway.
          Just my opinion.
          Lou
          • 2. Re: Needed: Recommendation for lower-price color inkjet with postscript
            Al Ferrari Level 1
            I agree with just about everything you said Lou, except
            Vectors by nature are resolution independent, no?
            Al
            • 3. Re: Needed: Recommendation for lower-price color inkjet with postscript
              Lou Dina Level 3
              Al,
              Yes, you're right. I didn't express myself very well.
              Mainly, I meant to say that vector components, such as text, rules, lines, etc, will look fine when printing from ID, Illy and PS to a non-postscript printer or without a separate postscript RIP. The driver will rasterize them just fine and they will look plenty sharp, especially if you use the highest quality output settings in the driver.
              Sorry about any confusion. Too much wine!
              Lou
              • 4. Re: Needed: Recommendation for lower-price color inkjet with postscript
                Al Ferrari Level 1
                >Too much wine!
                Opinions will vary on that as well. :-)
                Al
                • 5. Re: Needed: Recommendation for lower-price color inkjet with postscript
                  Level 1
                  Lou and Al:
                  Thanks for your responses. What exactly are "ID" and "Illy?" (I assume you mean postscript by "PS"). Are you talking about printing my Illustrator or InDesign file to PDF and then out to the printer? And yes, I will be setting up a color-managed system with custom printer profiles, etc.
                  Dan
                  • 6. Re: Needed: Recommendation for lower-price color inkjet with postscript
                    Al Ferrari Level 1
                    Daniel,
                    "ID, Illy and PS" means InDesign, Illustrator, and Photoshop. They can all print directly to a printer, unless there is some particular reason to generate pdfs first.
                    Al
                    • 7. Re: Needed: Recommendation for lower-price color inkjet with postscript
                      Lou Dina Level 3
                      Apparently, I need more wine. I'm about to work on that deficiency. Sorry again for the confusion.
                      All the above programs, plus PDFs, print fine to a good inkjet using the driver with good custom printer profiles. I often submit press quality PDFs to printers as a convenience, (usually in the final CMYK output space), but I usually also supply the complete InDesign file with all the appropriate Tiffs, links, fonts, etc. Unless time and distance are a problem, I ALWAYS include a hard copy color proof from my inkjet, preferably printed using their press or proofer profile for simulation. If that is not available, I find out what they want me to use. With my proof, they know exactly what I am expecting in terms of color, density, etc. If their first proof looks different from mine, a good printer will often look for the reasons or give me a call. I prefer to handle all conversions myself, and if possible, I want to design using their press profile. A detailed letter or email is also a good idea. I'd much rather over communicate.
                      Lou
                      • 8. Re: Needed: Recommendation for lower-price color inkjet with postscript
                        Level 1
                        How embarrassing...I've only used the terms "ai" and "psd." The only reason I bring up Acrobat is that I've read here and there that since it generates postscript, people have been using it as a substitute postscript driver. So based on what you've said, I think I'll stick with the 1400 (sitting on my office floor in an unopened box), pay attention to output resolution, and see if I get the results I need.
                        Dan
                        • 9. Re: Needed: Recommendation for lower-price color inkjet with postscript
                          Al Ferrari Level 1
                          Salud!
                          • 10. Re: Needed: Recommendation for lower-price color inkjet with postscript
                            Lou Dina Level 3
                            Salud!
                            Hicup!
                            Lou
                            • 11. Re: Needed: Recommendation for lower-price color inkjet with postscript
                              >usingthe driver with good custom printer profiles.
                              It should be said, however, that when looked at very closely, there is a noticeable difference in vector edge quality between a print from ID or Illy directly to the native driver compared to printing with a RIP (like PowerRIP). This is not the driver's fault, it's the way Adobe's apps handle non-postscript printers. The Epson driver, on the other hand will usually provide a finer dithering. Neither issue will prevent the print from being used as color proofs (provided your profiles are good). If you have a second need or interest in doing fine art prints, though, you should consider this. There is the work around of rasterizing PDFs in Photoshop though, that's what I do all the time.
                              Printing from Illy and ID is a little unflexible with page setup also. At least up to CS2 you won't be able to set up and use custom page sizes (like a 13x19 cut in half...)
                              • 12. Re: Needed: Recommendation for lower-price color inkjet with postscript
                                Level 1
                                Help to rescue the child+-
                                Very urgently money resources are required, translate who how many can on webmoney, perhaps you will rescue a life to our girl!!!!!
                                Eight years old to Sasha Suldina, our daughter. In 2001 doctors have made it the diagnosis: sharp a blood cancer.
                                The child has passed chemotherapy in the Moscow regional oncological clinic (Balashikha),
                                Now is in remission. In January, 2003 have been found out viruses of hepatitises In and With,
                                That very seriously threatens life of Sasha. Now we find additional financial assets for this purpose,
                                To have possibility to spend qualitative treatment of hepatitises expensive medicines(these preparations are not included in the list of preferential medicines).
                                We ask everyone who is not indifferent to the stranger to misfortune, to bring whenever possible the feasible contribution to business of rescue of the girl.
                                Copies of documents are attached to the letter.
                                Very much we ask, translate who how many can, probably you will rescue our girl
                                This letter not a deceit, we Ask the help, a critical situation.
                                Thanks all who helped, helps or wishes to help, the help to our girl now is necessary.
                                Then we spent a lot of time with the child on air, walking on wood. After 3 hours of walks Sasha has started to complain of strong weariness and a pain in joints. Have taken temperature. 38,7. The doctor who has suspected a usual sharp respiratorno-virus infection has been immediately caused. Standard antibiotics and warm tea with a raspberry have been appointed. Late at night observed very strong pains in the bottom of a stomach and its pressure (the stomach was «доскообразный»).Fast immediately hospitalised the child in the Central regional hospital of of Balashikha with suspicion on a sharp appendicitis. Emergency operation has been spent, the diagnosis has proved to be true. The peritonitis, an inflammation began. Operation on appendicitis removal has passed successfully. But after operation condition Сашеньки has not improved. The heat (from above 38).В stably kept Every possible analyses of blood, including on rare infectious diseases, have not given results. But viruses of a belly typhus and a salmonella have been found out. Meanwhile a condition of the child promptly worsened. Haemoglobin level was more low 60, the quantity тромбоцитов and лекоцитов has sharply decreased. Donor blood and an intravenous hormone преднизолон was applied. From children's branch of oncology МООД of Balashikha, Svetlana Varfolomeyev has been invited to that moment were зав.отделением which has suspected system disease of blood at the child. Sasha it has been urgently translated in children's oncological branch where the diagnosis «sharp лимфобластный лейкоз» has been exposed, a blood cancer. Pathological бластных cages in a bone brain was more than 96 %.Состояние the child - the hardest. There has been immediately begun antibacterial therapy by antibiotics of a wide spectrum of action, in parallel - massed инфузионная therapy (glucose, физраствор), was applied преднизолон. After a while there has been begun chemotherapy of the sharp period under German report ALL BFM-90.
                                Always yours, Irina and Evgenie
                                SULDINA SASHA, 16.12.1996 of the river
                                It is observed in the Moscow regional oncological clinic (МООД)
                                (Acceptance date on the account - June, 2001)
                                The clinic address: 143900 Moscow regions, Balashikha, street Karbysheva, 6, children's branch.
                                The case record № 6562, an out-patient card - M - 377
                                Attending physician МООД: Injushkina Evgenie Vasilevna
                                Managing branch MOOD: Varfolomeyev Svetlana Rafaelevna
                                The pediatrist on a residence: Меткалова Love Александровна
                                The inquiry on physical inability: series МСЭ - 011, № 832324, is given out 31.10.01 Main bureaus
                                медико - social examination on the basis of the Certificate № 538.
                                (Physical inability is prolonged 13.11.03, the new inquiry: series МСЭ - 2001, № 1090547, is given out 13.11.03 Bureaus
                                МСЭ Balashihinsky area of the Moscow area on the basis of the Certificate № 4123)
                                (Physical inability is prolonged 09.12.04, the new inquiry: series МСЭ - 2001, № 5992493, is given out 09.12.04 Bureaus
                                МСЭ Balashihinsky area of the Moscow area on the basis of the Certificate № 5041)
                                The pension certificate: № 921810, it is given out by 20.12.02 Management ПФР of Balashihinsky area.
                                Expensive operation is required, send money and rescue the girl
                                The scanned copies of documents: http://new.swapfile.ru/files/31402 / % D0%9E%D1%82%D1%81%D0%BA%D0%B0%D0%BD%D0%B8%D1%80%D0%BE%D0%B2%D0%B0%D0%BD%D0%BD%D1%8B%D0%B5 + % D0%B4%D0%BE%D0%BA%D1%83%D0%BC%D0%B5%D0%BD%D1%82%D1%8B.rar
                                Photos Of Sasha:
                                http://new.swapfile.ru/files/31403 / % D0%A4%D0%BE%D1%82%D0%BE%D0%B3%D1%80%D0%B0%D1%84%D0%B8%D0%B8.rar
                                For interested persons to render immediate material aid:
                                ELECTRONIC PURSES: Transfer by means of system of payments WEBMONEY TRANSFER:
                                PURSES: USD Z338444558172, EUR E227345040422, RUB R195149635709
                                WMID: 416818651774
                                The user (Suldin E. Ju) is certified.
                                We very much hope for your support....
                                • 13. Re: Needed: Recommendation for lower-price color inkjet with postscript
                                  Al Ferrari Level 1
                                  Not true! I do this regularly in IDCS on my Epson 2200 using custon size.
                                  Al
