0 Replies Latest reply on Jan 12, 2009 4:00 AM by CK_GSY
    Disable update
      I would like to disable Auto-Update when i install Adobe Air because everytime I want to install an Air application, the installation want to check the last version of Adobe Air by using proxy-account.
      I don't want use SettingManager, because it run locally
      I tried to use this follow registry key but don't change anything : <On Windows, add a DWORD value named UpdateDisabled to the HKey_Local_Machine\Software\Policies\Adobe\AIR registry key, and set the value to 1>
      If I install manually Adobe Air and I add the folder, sub-folder, files and certificate from SettingManager; it's OK
      If I use the msi extract and add the same files with an respond file, it's not run, the verification is already present
      Anyone have an solution because the Adobe Support just help on installation process
