5 Replies Latest reply on Apr 21, 2008 1:10 AM by (Brian_Carlick)
    Internal or External?
      I have a Coloredge CE210W, a really excellent monitor in my opinion! my question is should I continue to use the internal calibration system with my Eye One, as I am doing now or use the "external" Eye One software?
      Will one give a better profile/calibration than the other?
      Regds
      Brian
        • 1. Re: Internal or External?
          Brian,
          please read this diagonally:
          http://www.adobeforums.com/webx/.59b4c665
          In my humble opinion, the monitor-internal
          calibration (10 bpc LUTs) isn't visually
          better than the external graphics-card
          calibration (8bpc LUTs).
          I'm preferring the conventional=external
          calibration because I can then switch between
          D65 and D50 without touching the monitor.
          Monitor banding is an indicator for a bad
          graphics workflow (besides a very wrong adjust-
          ment). It doesn't help to use a monitor with
          less banding when it comes to the printing
          of synthetical gradient patterns on an 8 bpc
          printer. One has to make the source graphic
          more robust, for instance by adding noise.
          Best regards --Gernot Hoffmann
          • 2. Re: Internal or External?
            Level 1
            Gernot
            Thanks for your "humble" opinion, it is valued by many I am sure!
            just a couple of things, in your "diagonal" read you say
            "Please check the monitor profile in Photoshop's
            color settings.
            Your last profile should be there, otherwise
            PhS doesn't know it. "
            Just where is the mon profile shown in CS2, I couldn't find mine but I assume CS2 has found it as mon image to print OP is OK
            How would one check monitor banding?
            Regds
            Brian
            A sunny but chilly Aldeburgh UK
            • 3. Re: Internal or External?
              Brian,
              you'll find the monitor profile mentioned here:
              Photoshop CS2 > Edit > Color Settings > RGB
              Open list with right arrow
              Go to top of list
              In row 6: Monitor RGB - ...
              IMO, it's always sRGB if no monitor profile is
              available, but I didn't test this.
              Tests for monitor banding require test images,
              for instance here on p.16 ..:
              http://www.fho-emden.de/~hoffmann/optigray06102001.pdf
              My docs are always optimized for 72ppi (in Prof.Acrobat
              Edit > Preferences > Page Display: choose 72 ppi).
              Recommended zoom=200% says: the test image was created
              with 144 ppi.
              This might be helpful as well (concept for CRT monitors):
              http://www.fho-emden.de/~hoffmann/caltutor270900.pdf
              • 4. Re: Internal or External?
                Level 1
                Gernot
                Found it! and it shows my latest mon profile. I will check out the banding later, my granddaughters are here.........
                Brian
                • 5. Re: Internal or External?
                  Level 1
                  Gernot
                  Granddaughters have now gone home.........
                  My CE 210W does not show any signs of banding on yr charts so a good sign I think
                  I have another question but I will post as a separate topic
                  Thanks for yr help
                  Regds
                  Brian
                  A sunny Aldeburgh!
