3 Replies Latest reply on Nov 5, 2008 11:53 AM by (Christie_Ence)
    Merging Spot Colors in Distiller
      I am using ArcGIS (ArcINFO License) Production Line Tool Set to output an EPS file containing about 15-16 individual spot colors. These spot colors are divided into 5 different main colors: Black, Gold, Magenta, Blue and Green. Each plate refers to a specific tint percentage (For instance, there is a 100% Black, 49% Black, 25% Black, etc.) What I need to do is to merge all the Blacks, Golds, Magentas, etc. into the five main colors as individual plates. Can this be done in Adobe Distiller? Any ideas on how to do this?
      Thanks.
        • 1. Re: Merging Spot Colors in Distiller
          John Danek Level 4
          I don't think you can do it in Distiller. It sounds like you'd have to go back to the original document and converge the colors there. I wonder if you could open the EPS in Illustrator and create the colors there. I'm not familiar with "ArcGIS", but see if you can converge there first.
          • 2. Re: Merging Spot Colors in Distiller
            Level 1
            Also check the EPS' are they vector or raster separations? Haven't used PLTS but when I was looking intro setting overprints with Arc I found the only way was with PLTS but this generated raster files for the plates. If they are raster you may be able to combine in Photoshop with an action without any degradation.
            One thing to keep in mind layering these separations is what happens when a tint overlays a solid ink or vice versa?
            But I'm pretty sure you should be able to output the tints on the same fileWe have a meeting with ESRI's PLTS product manager tomorrow so while I won't be able to go into depth I'll run it past him.
            Also I wouldn't recommend Illustrator due to the complexity of maps that are usually output via this method and also the fact some postscript objects sometimes go a bit haywire when opened into Illustrator and these are often things not immediately apparent.
            • 3. Re: Merging Spot Colors in Distiller
              Level 1
              I was able to get the color separation from ArcMap. ArcMap uses a color management interface called "See Spot Color". By modifying the support file (SCS), it is possible to place multiple ink percentages on to the same plate.
              Thanks.
