1 2 Previous Next 66 Replies Latest reply on Mar 29, 2009 11:48 PM by (derek_Kimball)
    Assign- Convert - Proof Colors
      In Photoshop, I can choose to assign or convert to profile. This seems straight forward, I think.
      I was given images in ProPhoto RGB color space (8 bit). Just as a test, I did two things. I created a Proof setup that used Adobe RGB and Peceptual Rendering intent. Then, I also went to Assign Profile. Both cases the image was darker and lacked detail (given the smaller color space)...
      My working space for RGB is Adobe RGB with perceptual rendering intent.
      Next I turned the proof colors off and I converted the file to Adobe RGB. In this case, the color changed very little (was not dark at all).
      I thought I understood that if you assign a profile, the appearance on screen will differ (and the numbers will stay the same), If I convert, the numbers actually change.
      question: Why would the image look very dark when I was assigning the profile, but look the same as the original when converting?
        • 1. Re: Assign- Convert - Proof Colors
          (Marco_Ugolini) Level 1
          You know that
          i assigning a profile
          and
          i converting to a profile
          are two separate and quite different processes, don't you?
          • 2. Re: Assign- Convert - Proof Colors
            Level 1
            Yes, I believe a know the difference.
            In simple terms, I believe that assigning a profile, assigns a working "set of colors" (color space) for the person who is correcting. It does not change the color value of the pixels, but is simply a visual reprsentation of the image when confined to the assigned colors. and by embedding it, the next user down the pike will know which defined "color set" was used to make corrections. Converting actually will map colors from one space to another and uses the actual destination spaces pixel values in the file.... right?
            If this is the case....
            I still ask the question above
            • 3. Re: Assign- Convert - Proof Colors
              Level 1
              ASSIGN VERSUS CONVERT TO PROFILE
              >> Why would the image (change when) assigning the profile, but look the same as the original when converting?
              That behavior is 100% to be expected. I like to explain the difference between Assign Profile and Convert To Profile like this: http://www.gballard.net/psd/assignconvert.html
              The only time most users ever need to touch Photoshop> Edit> ASSIGN PROFILE is if the Source File is Untagged (and we need to PROOF it and/or edit it in a color-managed application like Photoshop).
              On the other hand, Ps> Edit> CONVERT TO PROFILE is a feature most of us use on a daily basis for example, Converting our high-gamut RGB working space to a target CMYK space, an sRGB web space, or a different space (profile) to hand it off.
              As a hard general rule, always USE EMBEDDED PROFILE first, then CONVERT TO PROFILE if it is not in the desired color space (profile).
              PROOF SETUP
              Photoshop> View> Proof SetUp: Profile
              AKA "Soft Proofing" is generally used to preview a target device profile (like a specific Printer/Paper/Ink profile, or a specific CMYK press profile).
              In most cases, Photoshop's Soft Proofing feature is very confusing in the theory department unless we understand why we are using SoftProofing.
              In this case, I would first get the Assign-Convert theory nailed down...and use Proof SetUp as sparingly as possible.
              BRUCE FRASER wrote the book(s) on Proof SetUp (Soft Proofing in Photoshop) http://www.creativepro.com/articles/author/127446
              • 4. Re: Assign- Convert - Proof Colors
                Ramón G Castañeda Level 4
                csullivan,
                The only time you use assign is when some moron hands you an untagged profile and you need to make an educated guess as to which color space said moron was using when he/she created and saved the file.
                CONVERT to profile strives to preserve the colors while changing the numbers. Assign maintains the numbers and changes/wrecks the colors.
                Maybe this old post will help you:
                Ramón G Castañeda, "Definitions for profiles" #3, 16 Nov 2008 5:17 pm
                • 5. Re: Assign- Convert - Proof Colors
                  Level 1
                  I somehow missed that thread, Ramón, but here is one of the best explanations I've read:
                  Eric Chan - 9:30am Nov 21, 08 PST (#71 of 82)
                  Camera Raw Engineer
                  I have not read the whole thread, but the easiest way to think of it is in terms of the language analogy.
                  Tagging/assigning is identification.
                  Converting means translation while preserving meaning.
                  Here's an example.
                  Suppose you hear a stream of words coming over the radio while driving your car. You don't understand it. Your friend sitting next to you says, "Oh, that sounds like Korean." That's tagging, or assigning. Your friend is identifying what the language is. There's no conversion/translation happening. Your friend may be correct, or incorrect. (For all you know, the real language might actually be Japanese.) Regardless, the central point is that this is what tagging/assigning means.
                  But now suppose you actually want to understand what those words mean (i.e., what the radio program is about). Then somebody has to translate it for you. This is "conversion." You ask your friend to translate the "Korean" to English, a language you do understand. What you hear from your friend are words in English, which are different from the original words coming over the radio (which are in Korean). But the meaning is the same (**). Going back to color management, "conversion" means that in general the underlying numbers change during the conversion process, but the color appearance stays the same.
                  Eric
                  (**) This assumes your friend actually knows Korean and translated it correctly.
                  • 6. Re: Assign- Convert - Proof Colors
                    Level 1
                    Thank you to both of you for technical and non-technical. The analogy of language is very good and would also support the theory that once you have a "translation" (conversion) and you attempt to re-translate back or to a different language (profile) that something may be lost in the translation....
                    I do have a good understanding of Assign and Convert. Your information just supports that. What I did not know is how Photoshop uses previews.
                    What I thought was that if a had a ProPhoto RGB file and assigned Adobe RGB that the preview would reflect in gamut colors, which in turn, would look very bad given the differences in size of color space. Convert (From ProPhoto), would actually change the pixel values to fit inside of the gamut of the destination profile (Adobe RGB).
                    Why is it that:
                    If all colors in the image from ProPhoto fit inside of the Adobe RGB profile to begin with, that the preview would chaange dramatically. Is it due to the size of the gamut of ProPhoto (i.e. the distance between color values)?
                    and just for clarification of the preview mode. If I do assign Adobe RGB profile in this instance, why do I not get the choice of rendering intents? I am assuming that the preview is in gamut colors (and others are clipped?)
                    thanks
                    • 7. Re: Assign- Convert - Proof Colors
                      Level 1
                      if you know (and have Honored) the Source Space in Photoshop, WHY are you still talking about ASSIGNING a different profile to it it is kind of a pointless experiment once you understand the point
                      if you want to change the Source Space (Source Profile) -- CONVERT
                      if you want to "Soft Proof" a Target Profile/Space in Photoshop -- use View> Proof SetUp: Target Profile
                      The Color Management System CMS CONVERTS the SourceSpace/File/Profile into MonitorRGB (the custom "calibrated" monitor profile) and PROOFs the color accurately on the screen -- this happens on the fly, automatically behind the scenes in Ps (we cannot turn it off since version 6).
                      The file (the document Source Space) is independent of Photoshop:
                      The Color Management System CMS, Photoshop, ONLY uses the monitor profile for one thing: To PROOF source file on the monitor (the monitor profile has zero to do with how the file prints).
                      The Color Management System CMS, Photoshop, ONLY uses the printer (target) profile Print Space for one thing: To PROOF source file on the paper (the printer profile Print Space has zero to do with how the file looks on the monitor)...www.gballard.net/psd/cmstheory.html
                      • 8. Re: Assign- Convert - Proof Colors
                        Level 1
                        >> once you have a "translation" (conversion) and you...re-translate back or to a different language (profile) that something may be lost in the translation....
                        EXACTLY
                        Conversions degrade color information...I like to keep my color conversions to an absolute minimum.
                        For example:
                        Capture in Camera RAW format
                        Open in Adobe Camera Raw 16-bit ProPhotoRGB
                        Edit in Adjustment Layers
                        Save MASTER FILE in that format
                        Open and resize and Convert to the Target Space
                        Save the production copy
                        That leaves my workflow with ONE conversion and fills my production copy with as much color information as possible.
                        • 9. Re: Assign- Convert - Proof Colors
                          > I do have a good understanding of Assign and Convert.Yes, I believe a know the difference.
                          Are you sure? Your earlier explanation felt a bit muddled:
                          I'm not sure. In
                          i actually simple
                          terms, the difference is this, as others have pointed out and I'm just restating:
                          b Assigning a profile
                          leaves the color
                          i numbers
                          in the file unchanged, but changes their
                          i appearance
                          (their
                          i "meaning"
                          in device-independent terms).
                          b Converting to a profile
                          i changes the color numbers
                          in the file, but
                          i keeps the appearance unchanged
                          (except for gamut mismatches, in which case the rendering intent decides how the out-of-gamut colors in the source are mapped to the destination).
                          I think it's important to understand this distinction and be able to state it as clearly as possible.
                          • 10. Re: Assign- Convert - Proof Colors
                            Level 1
                            MORE ABOUT ASSIGN PROFILE
                            Bruce Fraser wrote in a previous Adobe forum:
                            (You could change profiles a thousand times via Assign Profile and the image would not degrade) "Inasmuch as the numbers in the file wouldn't change, this is true. But it would display incorrectly, and convert to any other space incorrectly, so it's fair to say that while the integrity of the data hasn't been compromised, and you can rescue the file by assigning the correct profile, for all practical purposes, it's hosed."
                            • 11. Re: Assign- Convert - Proof Colors
                              csullivan,
                              Not wanting to appear rude, condescending or disrespectful, but like Marco, I really question the veracity of that statement. :/
                              • 12. Re: Assign- Convert - Proof Colors
                                I beg to differ. Conversions are
                                i necessary
                                in order to create the best fit of an image with its intended output medium (a press or other). There is nothing "degraded" about a well-done conversion to the output color space -- quite the contrary.
                                Though it's true that, once converted, such a file is of limited usefulness for
                                i further
                                conversions, for which it's far better to go back to the source image and start over.
                                Well, I see no reason to convert more than just once, from source to intended output -- once for each output directly from the source.
                                • 13. Re: Assign- Convert - Proof Colors
                                  Just as "G. Ballard" says re: "csullivan":
                                  >if you know (and have Honored) the Source Space in Photoshop, WHY are you still talking about ASSIGNING a different profile to it it is kind of a pointless experiment once you understand the point.
                                  Exactly. What is the point, after converting, of assigning a profile that's different from the one that the file has been converted to?
                                  Unless one is still unclear about the distinction...in which case it's better to admit it.
                                  • 14. Re: Assign- Convert - Proof Colors
                                    Level 1
                                    >> I beg to differ (about Conversions degrade color information)...There is nothing "degraded" about a well-done conversion
                                    Hmm... you may be right, Marco.
                                    I recall I got that bit of info in one of my forum discussions with Bruce Fraser or from one of his books, but I hope I am not confusing people with my recollections.
                                    To a lay person (like me) who is trying to conceptualize the basic theory that Converting a higher-gamut space like Adobe RGB or ProPhotoRGB to smaller-gamut spaces like a press CMYK or web sRGB space would have to clip or compress and/or stir up some colors to happen I guess that would be the basis of my point.
                                    In any case, it is probably a good idea for most people to make as few profile Conversions as possible based on simple common sense principles like if we Convert AdobeRGB to sRGB -- and back again -- we have probably lost (degraded) some color information that we can never get back.
                                    Let alone if we Assign (or Assume) sRGB to an AdobeRGB file -- hammer it back into shape in CMYK SoftProof mode and save it back out with no profile ;)
                                    How that theory may apply to the actual rocket science is over my pay grade and more likely suited to your technical expertise.
                                    BTW
                                    >> Converting to a profile changes the color numbers in the file, but keeps the appearance unchanged (except for gamut mismatches, in which case the rendering intent decides how the out-of-gamut colors in the source are mapped to the destination).
                                    That totally rocks...
                                    • 15. Re: Assign- Convert - Proof Colors
                                      Level 1
                                      All,
                                      The conversation has been great.
                                      When one is part of a large industry such as graphic arts, you will deal with all kinds (those who are first time graphic designers, free lance operators, etc.)
                                      Your assumptions are that each of these individuals will understand the dialog boxes which appear. What I was hoping was that I would be able to give a good explanation to those who are faced with such dialog boxes. I am never one to say "DO THIS BECAUSE." I am one who wants explain exactly what will happen if (you make the wrong choice)... and I have not come up with a very good example to explain TECHNICALLY what will happen if they choose to do such things (heck, many people have the ask check-boxes off in the color settings)
                                      The prime example is having to deal with those who like to use the new features of just realeased software. The why of such "effects" don't output is just as important as why to do things a different way (Remember when Illustrator transparency first reared its ugly head?)
                                      >>Unless one is still unclear about the distinction...in which case it's better to admit it.>>
                                      You missed the point completely. Knowing and using the correct workflow and processes is a VERY, VERY small part of the equation. Understanding what happens when you don't is more important
                                      • 16. Re: Assign- Convert - Proof Colors
                                        >To a lay person (like me) who is trying to conceptualize the basic theory that Converting a higher-gamut space like Adobe RGB or ProPhotoRGB to smaller-gamut spaces like a press CMYK or web sRGB space would have to clip or compress or stir up some colors I guess that would be the basis of my point.
                                        Sure, perfectly reasonable. Yet, my point is that it is the very purpose of a conversion to optimize an image for its intended output. No "degradation" there: only the achievement of a "best fit" within the circumstances.
                                        At the same time, a converted image, specially one converted to a standard CMYK color space from an RGB space like AdobeRGB or ProPhotoRGB, may well have undergone some substantial reduction of its color gamut (though not necessarily). That's why one should go back to the source file for further conversions to other color space destinations, in order to retain all the color gamut in the source that fits into any given destination.
                                        It makes no sense, for example, to cut the source's gamut to SWOP and then convert that converted file to Sheetfed, only to risk losing some of the color brilliance that could have been retained in Sheetfed in a conversion made directly from the source image.
                                        That's very kind of you. Thanks.
                                        • 17. Re: Assign- Convert - Proof Colors
                                          Definitely
                                          i not.
                                          >Understanding what happens when you don't is more important.
                                          How do you understand that if you don't understand what needs to happen so that things are done as intended?
                                          • 18. Re: Assign- Convert - Proof Colors
                                            Was DYP Level 3
                                            Let me throw this into the mix. There is a case for assigning (false profile).
                                            http://www.accessmylibrary.com/coms2/summary_0286-781223_ITM
                                            • 19. Re: Assign- Convert - Proof Colors
                                              Was DYP Level 3
                                              I found the whole article.
                                              http://www.ledet.com/margulis/Makeready/MA48-Fate_and_False.pdf
                                              • 20. Re: Assign- Convert - Proof Colors
                                                Level 1
                                                OK Marco,
                                                I overstated my stance.
                                                But oddly enough, some of my new responsibilities include finding out exactly what went wrong, where in process and with very little (if any) contact with the users. It makes it extremely difficult.
                                                • 21. Re: Assign- Convert - Proof Colors
                                                  Level 1
                                                  ASSIGNING "FALSE" PROFILES
                                                  then you always got the calibrated monitor issue -- if the genius Assigning profiles in Photoshop has a good monitor profile enabled to make a better call -- or if his monitor is so off he is actually hosing good color
                                                  Color Management is very simple in theory, but easily confused by smoke and mirrors and misinformation
                                                  I believe if one takes a few minutes time to learn the core basics of how profiles work, most of the rest will fall into place under commonsense logic and following the chain for the broken link
                                                  there is rocket science involved, but if the geniuses do their job, most of us will never have to think past the simple basics:
                                                  HONOR the Source Space
                                                  CONVERT to Target Space (or workflow)
                                                  Use GOOD PROOFING PROFILES for our devices
                                                  • 22. Re: Assign- Convert - Proof Colors
                                                    There is no such thing as a "false" profile.
                                                    Profiles are real and quite "true". This preposterous terminology was coined by Mr. Margulis, and as far as I know is only used by him and his acolytes.
                                                    When you assign a profile, you assign a profile. Period. There is absolutely nothing "false" about it.
                                                    The assigned profile may work or not with the image, visually speaking. This "false" appellation is bunk.
                                                    • 23. Re: Assign- Convert - Proof Colors
                                                      then that "we" stands for a group of totally deranged individuals. :|
                                                      • 24. Re: Assign- Convert - Proof Colors
                                                        By now it's clear that Mr. Margulis is fossilized in the stone ages.
                                                        There is no doubt that he can be a magician when it comes to color correcting images for press printing, but his stand on color management has no place in today's technology.
                                                        Unfortunately, my first attempt to get serious in the use of Photoshop years ago was through his Professional Photoshop book. I can now say in good conscience that my unfortunate and uninformed decision to read his book at that point set me back several years, or at least it delayed my understanding of color management by several years. :(
                                                        DeMargulisation ( Entmargulisierung) is an essential step in understanding color management.
                                                        • 25. Re: Assign- Convert - Proof Colors
                                                          For the sake of clarity, it must be pointed out that the OP has changed his user ID from csullivan to junglebunk . This information is necessary to understand the references to csullivan in replies to his posts.
                                                          • 26. Re: Assign- Convert - Proof Colors
                                                            >DeMargulisation (Entmargulisierung) is an essential step in understanding color management.
                                                            Das stimmt, mein freund!
                                                            • 28. Re: Assign- Convert - Proof Colors
                                                              Was DYP Level 3
                                                              Afraid to think outside of the box are we?
                                                              • 29. Re: Assign- Convert - Proof Colors
        On the contrary, DYP. We left the box behind a long time ago. Others haven't and are still stuck there.
        I don't even think about the box any more ordinarilyuntil someone brings the smelly, old, moldy box up.
        • 30. Re: Assign- Convert - Proof Colors
        What's
        i that
        supposed to mean? What's this got to do with any boxes? And what out-of-box experience would you wish to propose? Dan Margulis'?
        Try again.
        • 31. Re: Assign- Convert - Proof Colors
        Was DYP Level 3
        Nobody said you had to grasp the concept. If don't want to consider the option it bring to the table, so be it.
        I am not defending anyone. I just know what can be achieved by doing this.
        • 32. Re: Assign- Convert - Proof Colors
        Lou Dina Level 3
        DYP,
        I agree...."false profiles" have their place and can be a useful tool. They have come in handy on many an occasion in my professional work experience, (whether you call them a false profiles, temporary profiles, non-standard profiles, or whatever). Dan has some positions I consider silly and he can very very controversial and stubborn, but he also has some good information. Good information is good information, wherever it comes from. It doesn't makes sense to throw out the baby with the bathwater, just because you don't like the source. I disagree with many of his positions, but take what is worthwhile and incorporate it into my arsenal.
        I sure would like to see the rhetoric on this unmonitored forum softened a little bit. The intent is to learn, share, and help others, not skewer people we don't like or pummel the uninformed.
        Peace.
        Lou
        • 33. Re: Assign- Convert - Proof Colors
        Level 1
        FALSE PROFILES, alternate profiles, other profiles, real profiles, true profiles
        I haven't read anything by Mr. Margulis, but would have to put "false profiles" wording under writing style (and without reading how he set that wording up, I can only speculate what he means by that).
        I think it is best to read the author(s) whose writing style(s) you enjoy and can learn from...
        • 34. Re: Assign- Convert - Proof Colors
        pfigen
        I just skimmed this thread and it seems like the original question was never really answered. Forgive me if I missed it in there somewhere.
        The reason your ProPhotoRGB image gets darker when you assign AdobeRGB is that ProPhoto is gamma 1.8 while Adobe RGB is gamma 2.2. In this case it's the GAMMA mismatch, not the gamut mismatch.
        • 35. Re: Assign- Convert - Proof Colors
        Was DYP Level 3
        If you want to be narrow minded and not learn anything new.
        Look at what has happened with the big hoax of the last 10 years for example. I spite of all the factual historical and current evidence to the contrary there are some very narrow minded people that still believe it and vote politicians in who will stop at nothing to take our money and our liberties away based on that hoax.
        I hate narrow minded people.
        • 36. Re: Assign- Convert - Proof Colors
        There's a big difference between having an open mind and having a hole in your head, DYP.
        [Now editing my plonk list to include DYP on it.] Your comment has no place in these forums, DYP.
        • 37. Re: Assign- Convert - Proof Colors
        Was DYP Level 3
        Same for you.
        I was only pointing out uses for assigning a false profile (I don't know what better term to call it) that is sometimes real useful when wanting to achieve a certain look in a final converted to profile.
        Those that have used this know exactly what I am talking and those that haven't instead resort to name calling instead of even trying to understand it.
        That what I call narrow minded!
        • 38. Re: Assign- Convert - Proof Colors
        I don't see how such condescending statements advance
        i any
        conversation. If you wish to be specific, be specific. Otherwise I would prefer to be spared the posturing and the stench of superiority.
        • 39. Re: Assign- Convert - Proof Colors
        How about just "assigning a profile"? Anything wrong with using the terminology that
        i everyone else
        uses?
        You assign a profile, and, if it seems to fit, then it fits. If it doesn't, it doesn't. What is "false" about that?
        If you are given a pair of shoes that are too small for your feet, are you going to look for "false shoes" that are the right size for your feet, or just the right shoes?
        1 2 Previous Next
