1 2 Previous Next 68 Replies Latest reply on Oct 28, 2018 1:19 AM by lrosenth Go to original post
      • 40. Re: Mac PDF files not readable on PC
        lrosenth Adobe Employee
        Without seeing the PDF in question, the best answer I can give you is that the PDF was created improperly...
        While the PDF itself is Portable - the ability for certain aspects of the file format to be properly rendered require that the creator of the file follow the standard AND use best practices in preparing the file (eg. Embedding all fonts).
        As the expression goes - "garbage in, garbage out".
        • 41. Re: Mac PDF files not readable on PC
          obpobp Level 1
          Of course that's correct -- the file was improperly created. My question is: What can I do with it now?
          This is a file that was created by sub-contractor designers, so I can't just regenerate the file "properly". My question is whether there's any way to make sure that a PDF file I can read can be read by everyone else too.
          That's why I tried converting and opening it in different programs and saving in all sorts of formats -- I was hoping that there's some Adobe product that can always save a file "properly" (i.e. embedding all fonts etc.), given that it can read it.
          Is there?
          Thank you for your help.
          • 42. Re: Mac PDF files not readable on PC
            If you can post the PDF then I can tell you what is wrong with it.  Otherwise, anything I say is a guess (since my crystal ball is not functioning this week).
            • 43. Re: Mac PDF files not readable on PC
              obpobp Level 1
              Ok, here's the solution I found:
              Take the file that doesn't display correctly.
              Open it in Preview on a Mac
              Select Print, but then select the pdf option in the print menu and save as a ps (postscript) file
              Convert the postscript file using the unix ps2pdf command.
              The end result is a file that doesn't give any error messages under unix and displays properly in all viewers I've tested
              Mac:
              Preview
              Adobe Reader 9.2.0
              Acrobat 6.0.6 Professional
              Adobe Illustrator CS   (Illustrator complained a bit, but displayed it correctly).
              Windows:
              Acrobat 7.0 Professional
              Adobe Reader 8
              • 44. Re: Mac PDF files not readable on PC
                You do realize that the version of Acrobat and Illustrator you have installed on your Mac are:
                1) No longer supported by Adobe
                2) Not compatible with the OS that you have installed
                Refrying the PDF, as you have done, is a hack - it doesn't solve the problem, just works around it.
                • 45. Re: Mac PDF files not readable on PC
                  obpobp Level 1
                  Since I cannot reproduce the file from source because it was sent to me as it was, I can't think of another choice but to "re-fry" it. Is there?
                  The problem is quite independent from my software -- I can read the file anyway, the question was: How can I make sure it can be read by anyone (without the option of recreating it using CS4, for example)?
                  I'm testing as many old and no-longer-supported and incompatible versions of programs as I can get my hands on. Again: My problem is that I want this file to be readable with any program anyone might still be using, without being able to re-generate it.
                  By the way: Which of the programs are incompatible with my operating system?
                  • 46. Re: Mac PDF files not readable on PC
                    Level 1
                    When I create a pdf file.. I get a pop up that asks me what version of pdf
                    do I want it readable in.  I typically choose Ver7 or newer - but you can go
                    older than that.  But I'm not sure where that choice is generated from -
                    Adobe or Mac.
                    • 47. Re: Mac PDF files not readable on PC
                      obpobp Level 1
                      which program are you using to create the pdf?
                      • 48. Re: Mac PDF files not readable on PC
                        Level 1
                        Ok, just dug  through my programs to see where this pops up.  The problem is
                        I use several programs to create the PDF - iWorks, Preview (some nice tools
                        in there - and communicates better with my printer than Adobe), and CS4
                        Acrobat Pro.  I do a lot of graphics and send them via email for approval.
                        So in Acrobat I'll often use Document>Reduce File Size... and that is where
                        I get the choice of how I want it read.  Might be in other places, but
                        that's where I get the prompt.
                        • 49. Re: Mac PDF files not readable on PC
                          obpobp Level 1
                          Excellent, thank you. I'll try that too.
                          • 50. Re: Mac PDF files not readable on PC
                            BeeleJoachim
                            Naming conventions
                            Try to rename your document.
                            Avoid dots in filenames.
                            Remove all dots except ".pdf".
                            Example:
                            Rename
                            "10. Title pp. 40-56.pdf" to
                            "10 Title pp 40-56.pdf".
                            Now try to open the renamed file on the PC.
                            Does it work?
                            • 51. Re: Mac PDF files not readable on PC
                              BeeleJoachim Level 1
                              Naming conventions
                              Example:
                              Rename
                              Does it work?
                              • 52. Re: Mac PDF files not readable on PC
                                sdona87
                                I had problems reading PDFs created (not my me) with Quartz Context on Mac. Graphs read on e-book reader Sony PRS-650 (running Adobe Reader) were faulty. Same graphs created with Adobe were ok.
                                I found a workaround using Ghostscript:
                                gs -sDEVICE=pdfwrite -dNOPAUSE -dBATCH -dSAFER -sOutputFile=newfile.pdf file.pdf
                                The new files are perfectly readable on the reader now, and the pages are again text-based.
                                • 53. Re: Mac PDF files not readable on PC
                                  Pnaujeck
                                  I'm also experiencing the same problems,I want to upload a copy of the file but i don't know how!
                                  • 54. Re: Mac PDF files not readable on PC
                                    WebbDesignLLC
                                    I'm having trouble with my PC opening all the data in a PDF sent from my Mac. When the PC opens the PDF, a few lines of text will be missing here and there. What can i do to fix this?
                                    • 55. Re: Mac PDF files not readable on PC
                                      Dov Isaacs Adobe Employee
                                      PDF files are not platform-specific.
                                      How was the particular PDF file created? Programs? Joboptions?
                                      What program (and version) did you view the PDF file with on the Macintosh?
                                      What program (and version) did you view the PDF file with on Windows?
                                      Assuming you used either Adobe Reader or Acrobat on both platforms, I might suggest checking whether you have the latest video driver on your Windows system and if not, update that and try viewing the PDF file again. The fact that the file opens on Windows and I assume doesn't yield an error message would be indicative that the file was not corrupted in the e-mail transfer.
                                                - Dov
                                      • 56. Re: Mac PDF files not readable on PC
                                        Mainer12
                                        Just to add to the mix:  I downloaded PDF files and zip files containing PDFs from the net to my Mac.  I then dragged them to a thumb drive and tried to open them on a PC.  None would open.  All Adobe products were current.  Renaming would not work.  However, several things did work--eventually.  For the PDFs, I brought the drive back to the Mac and exported each PDF file back to the drive and replace the old file.  All were now readable on the PC.  For the zip files, I just opened each one on the thumb drive.  Folders were created on the drive and all were readable on the PC.
                                        A more complicated solution was to e-mail each file as an attachment and pick them up on the PC. They all opened.
                                        There might be an easier way, but I couldn't find it. ( Working in Lion and XP2 service pack 3.)
                                        • 57. Re: Mac PDF files not readable on PC
                                          cdisanto2
                                          I too am having problems with PC users viewing my PDFs. I have links in the PDFs to other PDFs, DOCs, PPTX, etc. and they are not able to open the links. Seems ok from Mac to Mac. I zipped the files for the PC users to download, could the zipping have something to do with it? (Acrobat 9, Mac OS 10.6.8)
                                          Thanks!
                                          • 58. Re: Mac PDF files not readable on PC
                                            Mainer12 Level 1
                                            One more thing.  The mail program was NOT Mac Mail, but Thunderbird.
                                            • 59. Re: Mac PDF files not readable on PC
                                              cyndi0111
                                              I have a situation where my customer is using a Mac with a Windows emulation.  When they scan an image on the Mac side, it saves a PDF, the image is clear and legible; however, when they open that image (PDF) on the Windows emulation the image is very distorted and the user cannot read the PDF at all.  Are there any known issues that would cause this?
                                              • 60. Re: Mac PDF files not readable on PC
                                                Please be specific and precise about the software being used to view the PDF, and the version. Also, if the PDF is viewed in a browser, email app etc. what is that app? There are lots of possible pieces of software so you'd need to start with that info. Don't assume Adobe Reader is involved, for instance.
                                                I think you could usefully obtain from the customer a screen shot and share it with us. "Distorted" could describe so many things. Ideally, a screen shot from the Mac side of the SAME computer showing the "happy" file too.
                                                • 61. Re: Mac PDF files not readable on PC
                                                  angelad23163095
                                                  Quartz PDFs are a constant nightmare where I work. They are slow to load, I get error operations and when you send these to print, they take forever to rip and sometimes won't print at all. We've tried everything. Even re-saving on the mac.
                                                  Mac Quartz PDFs are not reliable in my industry. I am a printer.
                                                  • 62. Re: Mac PDF files not readable on PC
                                                    MacOS “Quartz Context” PDF files are no better or worse than PDF files from many other sources (including PDF generated directly by Microsoft Office under Windows and PDF files from many “freeware” PDF generators) and your exceptionally generalized observations are not borne out by the experiences of many other printers. Perhaps the content is more the issue that the creator.
                                                    If you can't print a PDF that opens and displays without a problem in Adobe Acrobat, perhaps your print workflow leaves something to be desired.
                                                               - Dov
                                                    • 63. Re: Mac PDF files not readable on PC
                                                      123manovi
                                                      I have some files on MAC and i copied them in a USB and now open on Windows 7 PC . But they are not opening . File name also changed now the name of file start with '._' . Please help how to open that files in Windows 7 ? File format showing .pdf .
                                                      • 64. Re: Mac PDF files not readable on PC
                                                        You will see TWO files or directories, one with a name starting _ or dot. Maybe a directory called _MACOS_ or similar. This is what a USB disk written on Mac looks like for all Windows users.
                                                        IGNORE THESE and use the one with the original name only. If in doubt check the file sizes, and ignore the files that are too small.
                                                        • 65. Re: Mac PDF files not readable on PC
                                                          esmatullaha11133520
                                                          I have the same problem, that when I send a PDF file via email from windows OS to Mac OS, then it shows bat file in mac OS, and it is not readable, Is there any solution for solving this problem. thanks
                                                          • 66. Re: Mac PDF files not readable on PC
                                                            Email doesn’t always work. Try using http://wetransfer.com instead.
                                                            • 67. Re: Mac PDF files not readable on PC
                                                              shotgunpr
                                                              I have problems with printing this file created on Mac OS X High Sierra.  Also is problematic to open on PC.
                                                              WeTransfer
                                                              • 68. Re: Mac PDF files not readable on PC
        Printing it to what type of printer using what version of Acrobat Acrobat/Reader on what OS platform?
        1 2 Previous Next
