4 Replies Latest reply on Sep 19, 2008 12:35 PM by (Bret_Orsburn)
    String to Number conversion
      Hey all again,
      Is there a method or something to take a string like "21,000.00" and convert it to a number looking like "20000.00" so that I can run a calculation on it?
      util,printf doesn't seem to work.
      parseInt isn't part of acrobat to my knowledge
      parseFloat isn't part of acrobat to my knowledge
      Help!
      Bret
        • 1. Re: String to Number conversion
          Patrick Leckey Level 3
          parseInt does indeed work in Acrobat, since it is part of JavaScript 1.5.
          • 2. Re: String to Number conversion
            George_Johnson MVP & Adobe Community Professional
            In the case you posted, parseInt won't give you what you want:
            var s = "21,000.00";
            var n = parseInt(s); // result = 21, not 21000
            If you were to first remove the comma, it would work:
            var s1 = "21,000.00";
            var s2 = s1.replace(",", "");
            var n = parseInt(s2); // result = 21000
            George
            • 3. Re: String to Number conversion
              As with most JavaScript, there are multiple ways to test and to accomplish an end.
              It appears the offending character that is preventing the conversion of a string to a number is the inclusion of the thousand separator of ",". Removing this character allows any number of methods to work.
              One can use the "typeof " method to find the type of an item, like string or number for a variable; or "isNaN()" method to test for "Not a Number" of a parameter, true is not a number and false is a number.
              There is also the "Number()" constrictor to convert a string to a number or zero.
              The following script run on the cosnole:
              // paresInt
              console.println("parseInt(): " ) ;
              console.println("s1: " + s1 + " typeof: " + typeof s1 + " - isNaN(s1): " + isNaN(s1) );
              console.println("s2: " + s2 + " typeof: " + typeof s2 + " - isNaN(s2): " + isNaN(s2) );
              console.println("n: " + n + " typeof: " + typeof n + " - isNaN(n): " + isNaN(n) );
              // parseFloat
              console.println(' ');
              console.println("parseFloat(): " ) ;
              s1 = "21,000.00";
              console.println("s1: " + s1 + " typeof: " + typeof s1+ " - isNaN(s1): " + isNaN(s1) );
              n = parseFloat(s2); // result = 21000
              // Number
              console.println("Number(): " ) ;
              s1 = "21,000.00";
              var s2 = Number(s1.replace(",", ""));
              console.println("s2: " + s2 + " typeof: " + typeof s2 + " - isNaN(s2): " + isNaN(s2));
              // Number of a character
              console.println("Number(\"A\" ): " );
              s1 = "A";
              Produces the following results:
              parseFloat():
              s1: 21,000.00 typeof: string - isNaN(s1): true
              s2: 21000.00 typeof: string - isNaN(s2): false
              n: 21000 typeof: number - isNaN(n): false
              Number():
              s2: 21000 typeof: number - isNaN(s2): false
              Number("A"):
              s1: A typeof: string - isNaN(s1): true
              s2: NaN typeof: number - isNaN(s2): true
              undefined
              • 4. Re: String to Number conversion
                Level 1
                Thanks all! With the below code, if you enter 11,111.11, you will get a NUMBER value of 11111.11 which is perfect for what I need. You can calculate with it and such.
                var variable1 = Number((field1.valueAsString).replace(",", ""));
