2 Replies Latest reply on Nov 18, 2008 11:20 AM by (J._Hsu)
    Acrobat 9: Error when PDF form submit with file attachment
      Hi all,
      Hope you can provide some help with my PDF form submit issue. I am getting this error "There is no PDDoc associated with this CosDoc." in Acrobat 9 (Reader and Pro) when I try to submit a PDF form with a file attachment field (the file is specified). The same PDF form works fine in Acrobat 7 or 8 (Reader and Pro) with file attachment.
      If no file attachment is specified (user did not select a file) then the PDF form submits fine in acrobat 9. The form data submission format is in FDF. Same problem if I change to XFDF.
      There are no differences in the problem if the PDF form is created in Acrobat 7 or Acrobat 9, the same submit issue exists in Acrobat 9 but not in the older Acrobat versions.
      Is this a known issue and are there any workarounds/solutions?
      Thanks.
