1 Reply Latest reply on Nov 19, 2008 9:54 AM by Patrick Leckey
    Acrobat 4.0 & Windows XP
      When Running 4.0 on Windows XP to create a PDF doc from Word file, the transforming, PDF maker/distilling, and printing routines seem to run successfully (as indicated by application itself)and finally a "process succeeded" notation appears - BUT the application then closes completely down automatically and no PDF file has actually been created. Had been running ME and just (finally) installed XP upgrade. Perhaps this is a driver related issue. In case, I need a direct or work around resolution ASAP that does not require new software purchase. Thanks. Howard
        • 1. Re: Acrobat 4.0 & Windows XP
          Patrick Leckey Level 3
          Unfortunately Acrobat 4.x is not supported on Windows XP (Windows XP didn't exist when 4.0 was released). There is no workaround - you need to use a version of the software that was built to work with Windows XP.
          If you are simply looking for converting documents to PDF, you can use Acrobat.com (http://www.acrobat.com) which gives your 5 free conversions per month.
