6 Replies Latest reply on Mar 5, 2009 1:31 PM by kiyomi
    Batch processing prompting user each time
    kiyomi Level 1
      Hi, we have a batch job that adds a watermark and then adds a footer. The watermark and footer are defined in the sequence via the Edit option in the "Select commands..." window.
      Run common on: select folder
      Select output location: specific folder.
      When we run the sequence, it opens the first file in the folder and then prompts the user for the same watermark or footer settings already defined earlier. It evens defaults to the setting we entered originally. So the user clicks OK, gets prompted again, hits OK, etc....
      We can find no reason for this behavior. Any suggetions? Thanks.
