3 Replies Latest reply on Mar 25, 2009 6:12 AM by (Lainie_Strange)
    Problems with totaling a set of fields that are also calculated fields....???
    Level 1
      I'm using Adobe Acrobat 8 Pro, not within Lifecycle Designer.
      Here's an example of one of my forms:
      http://dese.mo.gov/divimprove/lmc/documents/prek3prek6.pdf
      See page 1, column 4
      Even though I have the total field of column 4 set under the calculate tab for that text field "Value is the sum of...." it is showing zero. It will not update as column 4 values update.
      But the trick is that each value in column 4 is a calculation also, (meaning it is column 1-column 3). Is this what is causing the problem? I'm trying to figure out how to get all the fields to time right to calculate in the proper order.
      What is the best way to do this??? I'm stumped.
      Thanks so much - Lainie
