1 Reply Latest reply on Feb 21, 2008 5:57 AM by (Werner_Frank)
    Open a PDF with restricted tools
      I heard that there is a lot what can be done with a PDF via scripting (restrictions in the PDF itself, not an extra viewer application) .
      What we should like to do in the PDF itself:
      - Use Local Fonts (disabled and not possible to enable)
      - Formfields allowed
      - Digital signatures allowed
      - Only the following commenting tools allowed
      - Rectangle Tool
      - Line Tool
      - Overprint option (enabled and not possible to disable)
      - Print menu Advanced
      - Enable "Simulate overprinting" and not possible to disable
      - Printer profile "Same as source (no color management)" and not possible to disable.
      - PDF should be compatible with Acrobat 5, 6, 7 and 8 (also for Acrobat Reader)
      If this all is possible how can we add the script in the PDF ?
        • 1. Re: Open a PDF with restricted tools
          I´m looking for some of this, too. E.g. I want to have a button
          in a PDF that toggles the "Overprint" option, I want to read out settings of "Use Local Fonts" and set it ---
          Setting Overprint works with a
          app.execMenuItem("Overprint");
          in Acrobat 7 -- however in Acorbat 8 it fails due to security restrictions ?
          Is there a way around this? (trustedFunctions only work on initializing the applications, batch and... )
          Regards
          Werner Frank
