4 Replies Latest reply on Nov 1, 2012 12:41 PM by Saulius Stonys
    Image in dialog(execdialog)
    Level 1
      Hy,
      I would like to insert an image in a dialog. And the resulting PDF should be visible in Acrobat Reader too.
      Here is my script without the image:
      var oDlg =
      description:
      elements:
      type: "static_text",
      type: "ok",
      // Dialog Activation
      function myFunction( )
      if(!done )
      done=1;
      app.execDialog(oDlg);
      Could You please show me what the script should look like to have an image in It?
      NB: I want replies about scripting not about how to that from acrobat IDE
      Thanx
        • 1. Re: Image in dialog(execdialog)
          Have your gotten your code to work?
          Try:
          // define dilog object
          var oDlg = {
          initialize: function (dialog1) {
          // create a static text containing the current date.
            var todayDate = dialog.store()["date"];
          todayDate = "Date: " + util.printd("mmmm dd, yyyy", new Date());
          dialog.load({ "date": todayDate });
          commit:function (oDlg) {
          // called when OK pressed
          app.alert("Done",3,0);
          cancel:function (oDlg) {
          // called when Canceled pressed
          app.alert("Canceled",3,0);
          description:
          name: "My Dialog", // dialog title
          elements:
          type: "cluster", elements:
          { // static text
          }, // end static text
          { // define ok cancel buttons
          type: "ok_cancel",
          ok_name: "Ok",
          cancel_name: "Cancel"
          } // end ok_canel buttons
          ] // cluster
          ] // end elements
          } // end description
          }; // end of dialog object
          • 2. Re: Image in dialog(execdialog)
            Thom Parker Adobe Community Professional
            Images for both dialogs and toolbar buttons are represented with a Generic Icon Stream. The stream object is very simple
            var oIconStm = {width:100, height:100, read: function(nBytes){..}};
            It includes the width, height, and a function for returning bytes from the image data. All this is outlined in the Acrobat JavaScript Reference, including the image format, which is 4 byte SRGB, where the S is the alpa channel.
            The easiest, best, and most robust way to deal with creating images and dialogs is to purchase AcroDialogs:
            http://www.windjack.com/products/acrodialogs.html
            , which is an Acrobat Plugin for doing this.
            But there is another way to put images in a dialog where don't have to worry too much about the image details. The "util" object contains a function for converting an Icon Object into a Generic Icon Stream that can then be used on either a toolbar button or in a dialog image element. This strategy only works well on within a document, but it can also be used, with a little creative scripting, in a folder level script.
            Here's a simple script:
            var oButIcon = this.getField("MyIconButton").buttonGetIcon();
            var oMyIcon = util.iconStreamFromIcon(oButIcon);
            var oDlg1 =
            initialize: function(dialog)
            dialog.load({"img1":oMyIcon});
            description:
            elements:
            type: "image",
            item_id: "img1",
            width: 100,
            height: 100,
            The image is stored on the current document in a button named "MyIconButton".
            • 3. Re: Image in dialog(execdialog)
              garek007 Level 1
              Tom,
              You mentioned that your script below is a folder level script. How does it get accessed from Acrobat? I see no UI button code adding a button to your menu in that script.
              • 4. Re: Image in dialog(execdialog)
                Saulius Stonys
                maybe there you could find an answer:
                http://xprepress.com/images-in-acrobat-dialog-1/
                http://xprepress.com/images-in-acrobat-dialog-2/
                Saulius Stonys
                www.xprepress.com
