3 Replies Latest reply on Feb 26, 2008 7:22 AM by Patrick Leckey
    Print some static_text  from a Dialog
      Hello,
      I have a dialog with some static text in it.
      How can I do to print it?
      I could add to the form a button but ... which action should be associated with it?
      Any suggestion is welcome!
      nb: the script must work on Reader too ...
        • 1. Re: Print some static_text  from a Dialog
          Patrick Leckey Level 3
          Here is the link to the SDK documentation:
          http://www.adobe.com/devnet/acrobat/?navID=documentation
          You will find a plethora of details regarding the print functions in there and it will also tell you which functions are available to Reader so that you can plan your script accordingly.
          • 2. Re: Print some static_text  from a Dialog
            Level 1
            Thank you.
            I went through the documentation and found the print command.
            But the point is that I want to print some static_text which is in a dialog at the document level
            And I am looking from suggestions on how to do it
            • 3. Re: Print some static_text  from a Dialog
              You would have to add the static text to a page on the document and then print that page.
              Acrobat does not provide any functionality to simply pass a string of text to the printer.
              If you wanted only the text and nothing else, you could create a new page, add the text to that page, print just that page, then delete the page. That would require some folder-level scripts though since some of the required functions will need a privileged context.
              You're kind of reinventing the wheel to do that though. If you require printing of just a simple string of text, use the OS-level print APIs and just use the JSObject through IAC to pass the required string out of the document so you can print just that.
