2 Replies Latest reply on Mar 7, 2008 3:28 PM by (Jansen_Neo)
    The zero in front
    Level 1
      Hi all
      Acrbat Professional 8
      Can someone please show me how to use javascript to leave the '0' in front of numbers? I've used the following to copy a number box but some how it left the zero in front out:-
      var name = this.getField("Name").value;
      event.value = name;
      Please help.
        • 1. Re: The zero in front
          Field format "none" or you code the custom Keystroke and format scripts.
          Custom calculation script:
          var nDecSep = 0;
          var cFlags ="0";
          var nWidth = 11;
          var nPrecision = ".2";
          var cConvCahr = "f";
          var cFormat = "%," + nDecSep + cFlags + nWidth + nPrecision + cConvCahr;
          event.value = event.value = util.printf(cFormat, name);
          For more information about the "util.printf()" method see the JavaScript API reference
          Acrobat JavaScript Documentation: http://www.adobe.com/devnet/acrobat/javascript.html
          Or create the custom Keystroke and format scripts as outlined:
          http://www.adobeforums.com/webx?7@@.3c0625b3/1
          and modify the custom format to:
          event.value = util.printf("%,0011.2f", event.value)
          or as needed for the desired display.
          and use your custom calculation script as is.
          • 2. Re: The zero in front
            Level 1
            Hi Geo the Scriptmaster
            Thanks for the reply, but that did not work. All I wanted is for the 2nd text box to show exactly what the I input in the 1st text box i.e.
            0123 showing 0123.
            I've seen your previous post showing how to do exactly this, but it did not work as well.
            Please help
            Jansen
