Is this possible and if so what is required to make it work.
Currently if you place print(false); at the document level and save the file. Every time you open it with Acrobat 8 you get a message telling you that the document is trying to print. This was not the case with version 7 and I understand all the security issues.
If you create a script like this:
printFile = app.trustedFunction( function ()
// Additional code may appear above
app.beginPriv(); // Explicitly raise privilege
this.print(false);
app.endPriv();
// Additional code may appear below.
Save it in the javascripts folder.
Then call this trusted function printFile(); at the document level you do not get the message. This is fine but a pain if you have to make each version of acrobat that you want this to occur on have the script installed.
I've been looking at certifying a pdf and having the Embedded high privilege JavaScript turned on within acrobat. Could I certify a pdf and when the user opens the pdf if they agree to my certificate the pdf will print without the print message coming up?
