1 Reply Latest reply on Mar 20, 2014 12:06 PM by larrcoppale
    How to call function addRequirements
      I'm trying following line from the "JavaScript for Acrobat API Reference":
      addRequirement(this.requirements.EnableJavaScripts, {[{cType: reqHandlers.JS, cScriptName: "requirement"}]});
      Acrobat says: "Invalid property id". Without cType and cScriptName everything is fine. Does anyone know how to use this?
      Christian Wiesbauer
        • 1. Re: How to call function addRequirements
          larrcoppale
          I did a simple copy paste from the Acrobat XI Documentation and I had the same issue.
          In fact the correct syntax is:
               addRequirement(this.requirements.EnabledJavaScripts, [{cType: "redHandlers.JS"; cScriptName: "reuirement"}]);
          You just need to remove the external accolade over second the parameter.
          Hope it helps at least someone.
          Cheers,
          David Corral
