6 Replies Latest reply: Jun 10, 2008 5:00 AM by Patrick Leckey RSS
    Read specific xmlns
    John.Kordas Community Member
      Can anyone tell me if this is possible?<br /><br />In the console I type this.metadata; and get<br /><br /><x:xmpmeta xmlns:x="adobe:ns:meta/" x:xmptk="Adobe XMP Core 4.0-c316 44.253921, Sun Oct 01 2006 17:08:23"><br /> <rdf:RDF xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"><br />  <rdf:Description rdf:about=""<br />    xmlns:xap="http://ns.adobe.com/xap/1.0/"<br />    xmlns:dc="http://purl.org/dc/elements/1.1/"<br />    xmlns:xapMM="http://ns.adobe.com/xap/1.0/mm/"<br />    xmlns:Iptc4xmpCore="http://iptc.org/std/Iptc4xmpCore/1.0/xmlns/"<br />    xmlns:photoshop="http://ns.adobe.com/photoshop/1.0/"<br />    xmlns:illustrator="http://ns.adobe.com/illustrator/1.0/"<br />    xmlns:pdf="http://ns.adobe.com/pdf/1.3/"<br />   xap:ModifyDate="2008-06-06T12:00:52+10:00"<br />   xap:CreateDate="2008-06-06T12:00:52+10:00"<br />   xap:MetadataDate="2008-06-06T12:00:52+10:00"<br />   dc:format="application/pdf"<br />   xapMM:DocumentID="uuid:5aa68b72-0d3c-7d46-8f2c-a3ddc3402225"<br />   xapMM:InstanceID="uuid:a7c80703-af0c-9047-aac8-fcc8f99ac9aa"<br />   Iptc4xmpCore:Location="City"/><br /> </rdf:RDF><br /></x:xmpmeta><br /><br />If I wanted to check via javascript that Iptc4xmpCore:Location has a value how do I return that value?<br /><br />Any suggestion would be appreciated.
        • 1. Re: Read specific xmlns
          Patrick Leckey Community Member
          You can read the section in the JavaScript for Acrobat API Reference on Doc.metadata, specifically Example 3. It shows how to do what you are asking.
          • 2. Re: Read specific xmlns
            Thanks PDL,
            I've seem this example but having a problem understanding how to call a container. I've been able to write to the metadata using that example but I'm can not seem to return the data.
            example:
            var AdsMLPPName = "AdsML Company"
            var AdsMLPPContact = "AdsML Contact"
            var AdsMLPPEmail = "AdsML Email"
            var meta = this.metadata;
            var myXMPData = new XML(meta);
            myx = new Namespace("adobe:ns:meta/");
            myrdf = new Namespace("http://www.w3.org/1999/02/22-rdf-syntax-ns#");
            mypdf = new Namespace("http://ns.adobe.com/pdf/1.3/");
            myxap = new Namespace("http://ns.adobe.com/xap/1.0/");
            mydc = new Namespace("http://purl.org/dc/elements/1.1/");
            myAdsML = new Namespace("http://adsml.org/xmlns/");
            var p = myXMPData.myrdf::RDF.myrdf::Description;
            if (p.@myAdsML::Marked.toString() == "" )
            {p[0] +=
            {AdsMLPPName}
            {AdsMLPPContact}
            {AdsMLPPEmail}
            } else {
            p.@myAdsML::PreperssName = AdsMLPPName;
            p.@myAdsML::PrepressContact = AdsMLPPContact;
            p.@myAdsML::PrepressEmail = AdsMLPPEmail;
            //Convert myXMPData into a string
            myNewXMPStr=myXMPData.toXMLString();
            //and assign it to the document metadata
            this.metadata = myNewXMPStr;
            This is fine but if I want to check the value of AdsML:PrepressName="AdsML Company" for example if i try metadata.PrepressName it returns undefined.
            • 3. Re: Read specific xmlns
              That certainly doesn't give me enough information to help you. How have you defined your 'metadata' variable and the PrepessName namespace object?
              • 4. Re: Read specific xmlns
                I have a dialog box that has 3 fields.
                When the user completes the dialog and click ok these 3 variables passed here:
                var AdsMLPPName = "AdsML Company" //Dialog variable 1 goes here
                var AdsMLPPContact = "AdsML Contact" //Dialog variable 2 goes here
                var AdsMLPPEmail = "AdsML Email" //Dialog variable 3 goes here
                Using the code above the variable values are put into the pdf metadata under the http://adsml.org/xmlns/ namespace defined by myAdsML = new Namespace("http://adsml.org/xmlns/");
                The problem I'm having is understanding how to check if these variables have been assigned previously and return them so I can display them is my dialog.
                Is it possible to check if the pdf has the http://adsml.org/xmlns/ namespace assigned and if so does a PrepressName, Contact and Email exist.
                Does this help?
                • 5. Re: Read specific xmlns
                  Ok the answer seems to be :<br /><br />myXMPData.myrdf::RDF.myrdf::Description.myAdsML::PrepressName;<br /><br />will return AdsML Company.<br /><br />I've go through the script line by line. Do you have to create a new XML()?<br /><br />var meta = this.metadata;<br />var myXMPData = new XML(meta);<br /><br />if I try for example meta::RDF i get:<br /><br />reference to undefined XML name <x:xmpmeta xmlns:x="adobe:ns:meta/" x:xmptk="Adobe XMP Core 4.0-c316 44.253921, Sun Oct 01 2006 17:08:23">\r\..................<br /><br />I'd like to check if a specific namespace has been added and if so does a specific description exist?<br /><br />Any suggestions would be appreciated.
                  • 6. Re: Read specific xmlns
                    Considering Doc.metadata simply returns the XML formated XMP metadata in a string, why not use the JavaScript search() method to simply see if your definition is contained in the string?
