5 Replies Latest reply on Jun 11, 2008 10:52 AM by (Edward_Gioja)
    addWatermarkFromFile in  livecycle
      In "Converting Acrobat® JavaScript for Use in LiveCycle Designer Forms" it says that doc.addWatermarkFromFile()
      Works in Livecycle designer
      Does NOT have a livecycle designer equivalent
      Has a ---- for LiveCycle designer javascript
      Does this mean I can or can not use this command? I use this command in Version 7 to place a picture of a signature on a form. When I try to use it on a LiveCycle form (doc = event.target), the console responds with:
      Exception in line 504 of function anonymous, script Folder-Level:App:config.js
      (504 being the addWatermarFromFile() command)
      If I open an older form (not LiveCycle), it works just fine.
        • 1. Re: addWatermarkFromFile in  livecycle
          Patrick Leckey Level 3
          I have successfully used it in LiveCycle Designer forms, but not in version 7 forms. Have you tried in a more current version of Designer?
          • 2. Re: addWatermarkFromFile in  livecycle
            Level 1
            My designer is 8.05.
            Perhaps you can tell me what I'm doing wrong. Here are two methods I've tried:
            Folder Level Javascript:
            AddWatermark = app.trustedFunction( function ( docptr)
            app.beginPriv();
            docptr.addWatermarkFromFile({
            cDIPath: "/C/temp/A425.jpg" (I've also tried pdf)
            app.endPriv();
            Menu that calls it:
            app.addMenuItem({
            cName: "TestDesigner",
            cUser: "Test Designer Form",
            cParent: "Tools",
            cExec: "AddWatermark(event.target)"
            _____________________________
            In the form itself, I've added a button.
            In the click action:
            event.target.addWatermarkFromFile({cDIPath: "/c/temp/A425.pdf"});
            I've tried wrapping the above in a beginPriv()/endPriv() but that causes an exception on the app.beginPriv()
            Thank you for your help.
            • 3. Re: addWatermarkFromFile in  livecycle
              Level 1
              BTW, when I was talking about version 7 I was just pointing out that the code works fine when I'm using an AcroForm as opposed to a LiveCycle form. This tells me, I think, that the syntax is correct.
              • 4. Re: addWatermarkFromFile in  livecycle
                You may want to clearly read the documentation. Note that for addWatermarkFromFile it says:
                Note:Can only be executed during a batch or console event.
                It DOES NOT say "application initialization" events, which is what folder-level scripts are. Your only options to run this method are during a batch sequence, from the console manually or via the JSObject from an external application.
                Just to make sure, I copied your code exactly (even put an A425.jpg in my C:\Temp directory) and executed it via the menu item. In the JavaScript console, I get the following error:
                NotAllowedError: Security settings prevent access to this property or method.
                Doc.addWatermarkFromFile:5:Menu TestDesigner:Exec
                I also tried with a certified document, still gives the security violation.
                • 5. Re: addWatermarkFromFile in  livecycle
                  Level 1
                  I was able to get around that, even according to the documentation, by putting it in a trusted function. That doesn't work anymore then?
