4 Replies Latest reply on Jul 2, 2008 5:19 AM by Patrick Leckey
    Controlling OCG display properties
      I am trying to automate the set up of my layers (OCG's) in Acrobat.
      Apparently, according to the JavaScript Reference (and Thom Parkers tutorial - http://www.acrobatusers.com/tech_corners/javascript_corner/tips/2006/create_use_layers/)
      there is no way to control the View/Print settings of the OCG layer via JavaScript.
      What I want to do, is set one OCG, to print only and the other to view only via JavaScript - but there isn't a documented way to do this. Apparently you can only do it the layer's properties window.
      Does anyone know of a workaround to setting this property?
      I am working in a 'Trusted Environment' and using app level JavaScripts to set this.
      I suppose, I could put a script in the WillPrint and DidPrint document actions to toggle the state of my layers before and after printing - but I thought that actually setting the layer properties would be 'safer' and more reliable.
      Any thoughts or suggestions would be appreciated.
      -Andrew
