This content has been marked as final.
Show 5 replies
1. Re: Open PDF file with Bookmarks Showing
Gilad D (try67) Oct 7, 2008 7:11 AM (in response to (Karen_Little))You don't need a script for this. Go to File, Document Options, Open Options (the name may differ slightly depending on your version) and there you can set all of these properties. -
2. Re: Open PDF file with Bookmarks Showing
(Karen_Little) Oct 7, 2008 8:52 AM (in response to (Karen_Little))That does it! Is there a way to make that a default setting? -
3. Re: Open PDF file with Bookmarks Showing
Gilad D (try67) Oct 7, 2008 12:28 PM (in response to (Karen_Little))How do you mean? Like for all files? -
4. Re: Open PDF file with Bookmarks Showing
Former Playtex Auditor Dec 13, 2011 9:36 AM (in response to (Karen_Little))Good morning. I was researching this same issue and found a solution for Adobe 9 Standard. I went into File > Properties > Inital View tab. On the first line, it says "Navigation tab:" I selected "Bookmarks Panel and Page" from the drop-down selection. Save your file, of course. Now, whenever someone opens this file, the bookmarks will show on the left side of the page and the document to the right.
5. Re: Open PDF file with Bookmarks Showing
Former Playtex Auditor Dec 13, 2011 9:39 AM (in response to (Karen_Little))
