3 Replies Latest reply on Mar 6, 2009 1:42 PM by sstanleyau
    AppleScripting an InDesign Paragraph Style
      There may be a better way to do this, but the workflow was created before being handed over to me.
      Basically, there is an existing AppleScript to paginate a product in InDesign, but the Paragraph Style Sheet line in AppleScript is very basic & uses the wrong font!
      There is an example:
      on SetTextStyles()
      tell application "Adobe InDesign CS2"
      tell active document
      try
      set firstLineStyle to paragraph style "FirstLine"
      on error
      set firstLineStyle to make new paragraph style with properties {name:"FirstLine", point size:6, font:"Arial Narrow"}
      end try
      What this 'firstLineStyle' should relly look like is this (based on the InDesign info):
      FirstLine
      [Basic Paragraph] + next: [Same style] + BentonGothicCond + Bold + size: 8 pt + leading: 9.5pt + tracking: -20 + pair kern method: Optical + tabs: count = 1, [position: 140 pt, alignment: right]
      I get scripting errors when I have tried (still learning AppleScript), things like the 'pair kern method' & 'tab counts' are not well liked.
      Can someone tell me what I need to do to get this to work?
      Thanks for any help.
        • 1. Re: AppleScripting an InDesign Paragraph Style
          sstanleyau Level 4
          Your first potential problem is that you're making the styles in the<br />application, not in a document. are you sure you want to do that?<br /><br />The best way to find out what you want is to ask for the properties you<br />want. So:<br /><br /> properties of paragraph style "FirstLine"<br /><br />Add "of document 1" if that's what you mean. Copy the result, and just<br />delete any that you don't want.<br /><br />-- <br />Shane Stanley <sstanley@myriad-com.com.au><br />AppleScript Pro Sessions <a href=http://scriptingmatters.com/aspro>
          • 2. Re: AppleScripting an InDesign Paragraph Style
            Level 1
            Well, I was given this, and it almost worked!
            Type is formatted spot-on, but the tab info is not included!
            Any idea's on the correct syntax for tabs?
            on SetTextStyles()
            try
            on error
            set firstLineStyle to make new paragraph style with properties {name:"FirstLine"}
            end try
            try
            set applied font of firstLineStyle to "BentonGothicCond"
            set font style of firstLineStyle to "Bold"
            set point size of firstLineStyle to 8
            set leading of firstLineStyle to 9.5
            set tracking of firstLineStyle to -20
            set kerning method of firstLineStyle to "Optical"
            set tab list of firstLineStyle to [{position:140, alignment:right}]
            end try
            end tell
            end tell
            end SetTextStyles
            • 3. Re: AppleScripting an InDesign Paragraph Style
              sstanleyau Level 4
              I can't recall whether CS2 had tab lists, or whether you had to make tab<br />stops, but the alignment should probably be "right alignment" (no quotes).<br />Otherwise, try this:<br /><br />make tab stop at firstLineStyle with properties {position:140,<br />alignment:right align}<br /><br />-- <br />Shane Stanley <sstanley@myriad-com.com.au><br />AppleScript Pro Sessions <a href=http://scriptingmatters.com/aspro>
