3 Replies Latest reply on Mar 16, 2009 9:12 AM by jay fresno
    Place an InDesign spread
    jay fresno Level 2
      Is there a method or a script that can place InDesign SPREADS into a single frame in another InDesign document? I know that I can print to PDF with Spreads turned on and place place the PDF spreads into InDesign, but I've not been able to figure out a way to do it with InDesign files other than placing one InDesign page at a time and grouping them before putting them inside a frame.
        • 1. Re: Place an InDesign spread
          Harbs. Level 6
          I don't think so, but out of curiosity; why do you care if it's two
          pages or one spread?
          Harbs
          http://www.in-tools.com
          • 2. Re: Place an InDesign spread
            Level 1
            You can use the technique I Bob described here:
            http://indesignsecrets.com/easily-add-captions-to-graphics-frames.php
            except that you'd create a spread-sized rectangle and then add two page-sized rectangles in it. Finally, placing each page into each of the internal rectangles.
            Not so different from what you're doing now, but the resulting structure is a rectangle with two pasted-in rectangles each containing a page.
            Dave
            • 3. Re: Place an InDesign spread
              jay fresno Level 2
              Harbs,
              The reason for having a spread is because it is more convenient for my layout. There is no space between the pages, but there is a space between the spreads.
              Dave,
              Thanks for your suggestion. Once I set up a template, your technique would work fine.
