1 Reply Latest reply on Mar 26, 2009 1:07 PM by Harbs.
    [JS][CS4] calling function from external file
    Steven.. Level 3
      When setting up an event listener, I currently use 1 of 2 options. Either I attach a file path to a script to run onInvoke, or I call a function which is included in the file creating the menu.
      The difference is that in order to be able to call a function, the file still has to be loaded into memory with '#targetengine session' or the like, where when using a path to a file it need not be loaded into memory.
      The issue with #targetengine... is that it can't be exported to jsxbin leaving the code exposed. The issue with a file path is creating many file that may share certain functions.
      So I was just wondering if it's possible to use a file path combined with a function name to call a specific function in a file without using #targetengine.
      Any help, or if I should try something totally different is appreciated.
      Steven
      RapidScriptUI http://www.scriptui.com
      idRTL http://sites.google.com/site/adoberighttoleft
