1 Reply Latest reply on Mar 27, 2009 5:41 AM by (James_M._White)
    CS3 findchangelist.txt
      Hi -- I am trying to change a format using the findchangelist.jsx script with the findchangelist.txt. I have had good luck with it except in two areas: paragraph alignment and case. In the changeProperties part of the text file, I have tried {justification:"alignCenter"} for paragraph alignment and {capitalization:"allCaps"} or {capitalization:"uppercase"} for case. Neither work. This is easily accomplished using the find/change command in InDesign, so I assume there's a way to script it using the findchangelist javascipt. Any ideas on what I am doing wrong? thanks
