1 2 Previous Next 61 Replies Latest reply on Aug 20, 2007 4:56 AM by (DaveSaunders) Go to original post
      • 40. Re: With CS2, some things have changed
        Level 1
        The syntax of adding a page reference to an index topic has changed. In effect the first two parameters have been combined.
        Where in CS you would have (leaving out the last two optional parameters PageReferenceLimit and PageNumberStyleOverride, which didn't change):
        myTopic.pageReferences.add(myStory, myIndex, PageReferenceType.currentPage);
        where myStory is the story in which the pagereference is and myIndex the index in the story (storyoffset) where the pagereference is.
        In CS2 this would become:
        myTopic.pageReferences.add(myStory.insertionPoints[myindex], PageReferenceType.currentPage);
        Although formally the first parameter of pageReferences.add is of the type Text, an insertionpoint will be accepted.
        Teus
        • 41. Re: With CS2, some things have changed
          Peter Kahrel Adobe Community Professional & MVP
          Re: pageReference
          You don't need an index or any (direct) reference to a story either. You could cycle through a collection of found items, as in
          myItems = app.activeDocument.search( 'wildebeest' )
          for( i = myItems.length-1; i > -1; i-- )
          myTopic.pageReferences.add( myItems[i], pageReferenceType.currentPage )
          Peter
          • 42. Re: With CS2, some things have changed
            Level 1
            That's right Peter: in CS2 you only need a parameter sourceText; this can be any text item. I just gave the example to illustrate how to convert CS scripts to CS2.
            Teus
            • 43. Re: With CS2, some things have changed
              Hi, I'm looking for an Acrobat patch. Does anybody has one? My InDesign isn't any longer able to read Acrobat. Maybe it is also unable to open QUark. Acro Writer isn't able to write. Several problems. Maybe there is a loss of dates.
              • 44. Re: With CS2, some things have changed
                Level 1
                This is surely not the place to look. Why not try one of the Acrobat forums.
                I'll leave your message and this response here for a day and then delete both.
                Dave Saunders
                Host
                PS: I have already deleted the duplicates you left attached to other messages in this forum.
                • 45. Re: With CS2, some things have changed
                  Level 1
                  Hi I've seen also some changes for the Excel import preferences. On CS you could set the select sheet with:
                  iApp.ExcelImportPreferences.SheetName = sheet
                  iApp.ExcelImportPreferences.RangeName = range
                  iApp.ExcelImportPreferences.DecimalPlaces = 3
                  This works no more on CS2. That's really desapointing because it was a great feature for automated import.
                  • 46. Re: With CS2, some things have changed
                    Level 1
                    All three of those properties are apparently still supported by the object model (according to the CS2 scripting reference). Are you sure you're not suffering from a problem elsewhere in your script? Or maybe this is a bug. It doesn't look to be a deliberate change in functionality.
                    Dave
                    • 47. Re: With CS2, some things have changed
                      Level 1
                      Dave,
                      You're right, all properties are supported, but they doesn't seem to work as in CS anymore. I tried to run a simple script using this propoerties, it works fine in CS but setting those properties in CS2 is useless. maybe it's a bug.
                      • 48. Re: With CS2, some things have changed
                        Level 1
                        Did you make sure that your TableFormattingOptions were set for formatted input? That could be a factor here.
                        Dave
                        • 49. Re: With CS2, some things have changed
                          Level 1
                          I tried to add the TableFormattingOptions, but it doesn't change the result. The real problem is when I use the command "Place", Indesign should use the "sheetname", "RangeName",... properties if they have been set previously. But in my case I set all the properties of existing sheets in my excel file, but at the execution of the place command in my script, the import window still open asking me which sheet to import.
                          • 50. Re: With CS2, some things have changed
                            Level 1
                            Ah, that's a different issue. There is a bug that I reported a month or so ago. I'm not sure if I reported here, though. Here's how I got around the problem of the no-iteraction flag in the place command not working:
                            // 1. Import Excel File
                            var myFile = File.openDialog("Choose an Excel file");
                            if (myFile == null) { exit() }
                            if (app.version == 3) {
                             app.userInteractionLevel = UserInteractionLevels.neverInteract;
                            } else {
                             app.scriptPreferences.userInteractionLevel = UserInteractionLevels.neverInteract;
                            myDoc = app.documents.add();
                            setXLimportPrefs();
                            try {
                             myDoc.pages[0].place(myFile,[0,0],undefined,false,true);
                            } catch (e) {
                             alert (e + " " + app.excelImportPreferences.errorCode);
                             exit();
                             app.userInteractionLevel = UserInteractionLevels.interactWithAll;
                            } else {
                             app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
                            [snip]
                            function setXLimportPrefs() {
                             with (app.excelImportPreferences) {
                              alignmentStyle = [AlignmentStyleOptions.spreadsheet,
                                AlignmentStyleOptions.leftAlign,
                                AlignmentStyleOptions.rightAlign,
                                AlignmentStyleOptions.centerAlign][0];
                              //decimalPlaces = 3;
                              //errorCode = 0;
                              //preserveGraphics = true; // Not sure what this does either
                              //rangeName = ""; // Hopefully leaving this blank will cause ranges to be ignored
                              //sheetIndex = 0;
                              //sheetName = "";
                              //showHiddenCells = true;
                              tableFormatting = [TableFormattingOptions.excelFormattedTable,
                                TableFormattingOptions.excelUnformattedTable,
                                TableFormattingOptions.excelUnformattedTabbedText][1];
                              useTypographersQuotes = true;
                              //viewName = "";
                            As you can see, I ended up commenting out most of the import preferences.
                            Oh, this is JavaScript, so you'll need to translate.
                            Dave
                            • 51. Re: With CS2, some things have changed
                              Level 1
                              Thanks for your script Dave.
                              But the problem is the same, because you can't specify the sheet and zone you want to import in your script. It seems I should have a file for each sheet in the excel file :(
                              Serge
                              • 52. Re: With CS2, some things have changed
                                Level 1
                                Hi Dave
                                I finally decided to try make an import in Javascript and it works a lot
                                better. I "uncommented" the following lines
                                sheetName = "mysheetname";
                                rangeName = "xx:yy";
                                And it work perfectly well! selecting the right sheet!
                                I think there is a problem with the VBS feature. I'll continue in javascript then.
                                Thanks for your help.
                                Serge
                                • 53. Re: With CS2, some things have changed
                                  Level 1
                                  Ah, I was going to asked if you'd tried uncommenting those two lines. Glad it worked.
                                  Dave
                                  • 54. Re: With CS2, some things have changed
                                    I am not a scripter but I'm hoping someone can help me with a problem given that it's likely to be small. The script below works in version 2.0 but not version CS2. This handy little thing saves me hours of work!
                                    Any help is very much appreciated.
                                    tell application "Adobe InDesign CS2"
                                    tell document 1
                                    set theSelection to selection
                                    repeat with anItem in theSelection
                                    set theTarget to anItem
                                    set theClass to class of theTarget
                                    if theClass is in {EPS, PDF} then -- if the image is selected by direct tools
                                    set theTarget to parent of anItem
                                    end if
                                    if page item 1 of theTarget exists then
                                    tell theTarget
                                    «event K2 fitc» given «class givn»:content to frame
                                    set horScale to round (horizontal scale of page item 1) + 0.5
                                    -- add 0.5 %
                                    set vertScale to round (vertical scale of page item 1) + 0.5
                                    -- add 0.5 %
                                    if horScale is greater than vertScale then
                                    set vertical scale of page item 1 to horScale
                                    set horizontal scale of page item 1 to horScale
                                    else
                                    set horizontal scale of page item 1 to vertScale
                                    set vertical scale of page item 1 to vertScale
                                    end if
                                    «event K2 fitc» given «class givn»:center content
                                    end tell
                                    end if
                                    end repeat
                                    end tell
                                    end tell
                                    • 55. Re: With CS2, some things have changed
                                      sstanleyau Level 4
                                      tell application "Adobe InDesign CS2"<br />    set theSelection to selection<br />    <br />    repeat with anItem in theSelection<br />        set theTarget to anItem<br />        if exists graphic 1 of theTarget then<br />            set theTarget to graphic 1 of theTarget<br />        else<br />            set theClass to class of theTarget<br />            if theClass is not in {EPS, PDF} then<br />                set theTarget to {}<br />            end if<br />        end if<br />        if theTarget is not {} then<br />            tell theTarget<br />                fit parent given fill proportionally<br />                set horScale to round (horizontal scale) + 0.5<br />                -- add 0.5 %<br />                set vertical scale to horScale<br />                set horizontal scale to horScale<br />                fit parent given center content<br />            end tell<br />        end if<br />    end repeat<br />end tell<br /><br />-- <br />Shane Stanley <sstanley@myriad-com.com.au>
                                      • 56. Re: With CS2, some things have changed
                                        Level 1
                                        Thanks Shane. People like you make the world a better place!
                                        • 57. Re: With CS2, some things have changed
                                          Level 1
                                          I couldn't find any of the commands for dealing with InCopy stories in the scripting reference. Commands like check in and check out. I looked under Links and under Stories and did a search for InCopy. Am I looking for the wrong thing?
                                          ID has made it easy to export all stories to InCopy, but it doesn't make it easy to unlink. You have to select all the stories in the links pallet, choose check out and then unlink. It doesn't seem like much, but if you have 40 documents with multiple InCopy stories each, it can be time consuming. There is also no way to do a global check out of all IC stories in all the open documents which would be handy for making global changes like changing a font or doing an all documents find/replace.
                                          • 58. Re: With CS2, some things have changed
                                            duplicate() has changed. In CS2 you can now add an offset to duplicate an object at a certain position. To duplicate an object and move the duplicate 4cm to the right and 3cm down, this can be done with one statement in CS2:
                                            myObject.duplicate(['3cm',4cm'])
                                            In CS1 you need two steps: duplicate and move:
                                            myObject.duplicate()
                                            myObject.move(undefined,['3cm',4cm'])
                                            Peter
                                            • 59. Re: With CS2, some things have changed
                                              Is there a breakdown on the change of syntax for AppleScript as well? I have run into a few problems with updating scripts for CS2, and while I have been able to find the solutions with the help of this thread and the scripting guide the latest one I don't see a reference to. Specifically making an inline graphic (rectangle) in the text flow is not working in CS2.
                                              • 60. Re: With CS2, some things have changed
                                                can u tell how to place assets in a library using adobe indesign CS3
                                                • 61. Re: With CS2, some things have changed
                                                  I answered in the topic: With CS3, some things have changed.
                                                  Dave
                                                  1 2 Previous Next
