19 Replies Latest reply on Aug 21, 2008 1:28 PM by (Keith_Cooper)
    DoScript CS3 VB to VB
      Can you give me an example (both for the script sending the parameters and for the script receiving the parameters) of using the DoScript command in VBscript to call another VBscript?
      For an example, I need 16 scripts to do the same thing, the only difference is three parameters, myGroupCode, myTemplateForm and myPrintPercent.
      The name of the 16 scripts will be the group code, (example CI.vbs, CO.vbs, etc.) They will contain the 3 parameters and each will call a script called CreateBatch.vbs (it displays a dialog to input the batch number, open the template, places the tagged text file, etc.)
      Archie
        • 1. Re: DoScript CS3 VB to VB
          Level 1
          Hi Archie,
          Here's an example:
          Set myInDesign = CreateObject("InDesign.Application.CS3")
          myVBScript = "myResult = msgbox(arguments(0), vbYesNo , arguments(1))" & vbCr
          myVBScript = myVBScript & "If myResult = 6 Then" & vbCr
          myVBScript = myVBScript & "myResult = ""Yes""" & vbCr
          myVBScript = myVBScript & "Else" & vbCr
          myVBScript = myVBScript & "myResult = ""No""" & vbCr
          myVBScript = myVBScript & "End IF" & vbCr
          myVBScript = myVBScript & "Set myInDesign = CreateObject(""InDesign.Application.CS3"")" & vbcr
          myVBScript = myVBScript & "myInDesign.scriptArgs.SetValue ""Result"", myResult" & vbcr
          myInDesign.DoScript myVBScript, idScriptLanguage.idVisualBasic, Array("Hello from DoScript", "Your message here.")
          MsgBox "User clicked: " & myInDesign.ScriptArgs.GetValue("Result")
          In theory, we're supposed to be able to get values back from a script run using DoScript directly, but I couldn't get it to work, so I used ScriptArgs.
          Ole
          • 2. Re: DoScript CS3 VB to VB
            Level 1
            Thank you for your quick reply.
            Sorry, but I'm still having a problem understanding this, or maybe the DoScript command doesn't function like think. I'm a business basic programmer, and I'm trying to relate this to that. With business basic you have one program call another using a call command, like CALL "PROGRAM_NAME",A$,B$,C$ and the program you call (the public program, like to select a printer) has a command like ENTER A$,B$,C$
            So, if I have a script named PI.vbs calling CreateBatch.vbs with three variables named myGroupCode, myTemplateForm and myPrintPercent what would the section of code look like in PI.vbs & CreateBatch.vbs? In my case I don't need any info returned back to PI.vbs.
            Archie
            • 3. Re: DoScript CS3 VB to VB
              Level 1
              Hi Archie,
              It's the same thing, whether you use a script file or a string. The start of CreateBatch.vbs would look like this:
              myGroupCode = arguments(0)
              myTemplateForm = arguments(1)
              myPrintPercent = arguments(2)
              When you call CreateBatch from PI.vbs, the line would look like this:
              Rem You'll have to fill in your own file path for CreateBatch.
              Rem This assumes that you've already defined myGroupCode, myTemplateForm,
              Rem and myPrintPercent.
              myInDesign.DoScript "c:\CreateBatch.vbs", idScriptLanguage.idVisualBasic, Array(myGroupCode, myTemplateForm, myPrintPercent)
              Ole
              • 4. Re: DoScript CS3 VB to VB
                Level 1
                hi Archie,
                because you build script from scratch - you can insert arguments in script's code:
                start = 5
                stop = 10
                myScript = myScript + "for a="+CStr(start)+" to " + CStr(stop)+vbcr
                myScript = myScript + " myTF.Contents=CStr(a)" + vbcr
                myScript = myScript + "next" + vbcr
                so when script will be executed - it will looks like:
                for a=5 to 10
                next
                and in case you want to retrieve/return some values from compiled script - use .InsertLabel and .ExtractLabel
                myScript = myScript + "myDocA.InsertLabel(""ResultA"",a)" + vbcr
                ResultA = myDocB.ExtractLabel("ResultA")
                where:
                - myDocA is reference in compiled script
                - myDocB is reference in main script
                I hope this helps :)
                robin
                www.adobescripts.com
                • 5. Re: DoScript CS3 VB to VB
                  Level 1
                  Hi Archie, Robin,
                  Jonathan just reminded me--if you use a variable named "returnValue," you can send a value back to the original script (no need for ScriptArgs). So:
                  myVBScript = "returnValue = msgbox(arguments(0), vbYesNo , arguments(1))" & vbCr
                  myResult = myInDesign.DoScript(myVBScript, idScriptLanguage.idVisualBasic, Array("Hello from DoScript", "Your message here."))
                  MsgBox "User clicked: " & myResult
                  Ole
                  • 6. Re: DoScript CS3 VB to VB
                    Level 1
                    Great! That worked, I didn't need to return values. Just one more question, I hope. Below is the code for the program that calls CreateBatch.vbs. It there any good way to avoid having the path hard coded for CreateBatch.vbs?
                    Rem PI Script
                    Rem SCRIPT INFO
                    Rem -----------
                    Rem Description:
                    Rem Call CreateBatch.vbs
                    Rem SET VALUES
                    Rem ----------
                    Dim myInDesign
                    Set FileSys = CreateObject("Scripting.FileSystemObject")
                    myGroupCode = "PI"
                    myTemplateForm = "SI_Page"
                    myPrintPercent = "100"
                    Rem CALL CREATEBATCH SCRIPT
                    Rem -----------------------
                    myInDesign.DoScript "C:\Program Files\Adobe\Adobe InDesign CS3\Scripts\Scripts Panel\CreateBatch.vbs",
                    idScriptLanguage.idVisualBasic, Array(myGroupCode,myTemplateForm,myPrintPercent)
                    • 7. Re: DoScript CS3 VB to VB
                      Level 1
                      Hi Archie,
                      Sure. The Application object contains the property ActiveScript, which contains the path to the current script. So you can use the FileSystemObject to find other scripts relative to the VBScript.
                      Take a look at the myFindFile and myGetFileName functions in the FindChangeByList.vbs example script (it's installed by default with InDesign CS3). They show how to get a script or support file of a given name relative to the executing script.
                      Ole
                      • 8. Re: DoScript CS3 VB to VB
                        Level 1
                        Hi Olav,
                        I have been using the DoScript command with great success with your help, but now I need to use the command to return parameters. I looked thru the prior emails and I still have not been able to understand how I would get the return value. Below is the section of code for the DoScript command. How would I get the values for myLabelPrinter, myManuscriptPrinter and myBatchFolder?
                        Archie
                        Rem DOSCRIPT ROUTINE
                        myMountLetter = "N"
                        myMountSize = "12"
                        myActiveScript = myInDesign.ActiveScript
                        Set myFileSystemObject = CreateObject("Scripting.FileSystemObject")
                        myScriptPath = myFileSystemObject.GetFile(myActiveScript).ParentFolder.Path
                        myDoScript = myScriptPath + "\zLabelParameters.vbs"
                        myInDesign.DoScript myDoScript, idScriptLanguage.idVisualBasic, Array
                        (myMountLetter,myMountSize,myLabelPrinter,myManuscriptPrinter,myBatchFolder)
                        • 9. Re: DoScript CS3 VB to VB
                          Level 1
                          instead of:
                          you need to write:
                          myResult = myInDesign.DoScript(myDoScript, idScriptLanguage.idVisualBasic, Array)
                          and in body (for example at end) of script you call:
                          returnValue = myTextFrame.Contents ' only example
                          robin
                          • 10. Re: DoScript CS3 VB to VB
                            Level 1
                            Thanks, I made the changes below and added returnValue = myLabelPrinter to the script zLabelParameters.vbs and that worked, but what if I need to return more than one varible?
                            Archie
                            (myMountLetter,myMountSize,myLabelPrinter,myManuscriptPrinter,myBatchFolder))
                            MsgBox "myLabelPrinter=" & myResult
                            • 11. Re: DoScript CS3 VB to VB
                              Level 1
                              it's easy :) convert to text (numeric expressions) and join with TAB - and split ;)
                              in sub-script:
                              returnValue = CStr(res1) + vbTab + CStr(par2) + vbTab + CStr(par3)
                              in main-script:
                              Dim myRes as Variant
                              myResult = myInDesign.DoScript(...)
                              myRes = Split(myResult, vbTab)
                              and (if you don't set OPTION BASE 1):
                              myRes(0) <- res1
                              myRes(1) <- res2
                              myRes(2) <- res3
                              robin
                              • 12. Re: DoScript CS3 VB to VB
                                Level 1
                                Great! That worked. I'm listing the finished code to help anyone else that uses this post because I find code examples the best way to learn.
                                Archie
                                myResultArray = Split(myResult, vbTab)
                                myLabelPrinter = myResultArray(0)
                                myManuscriptPrinter = myResultArray(1)
                                myBatchFolder = myResultArray(2)
                                Line from zLabelParameters:
                                returnValue = cStr(myLabelPrinter) + vbTab + cStr(myManuscriptPrinter) + vbTab + cStr(myBatchFolder)
                                • 13. Re: DoScript CS3 VB to VB
                                  Level 1
                                  Hi Robin,
                                  How do you return array values using the DoScript command? Below is an example where myStampRows is an array.
                                  Archie
                                  myMountLetter = arguments(0)
                                  myMountSize = arguments(1)
                                  myMountNumber = arguments(2)
                                  myLabelSize = arguments(3)
                                  myStampCols = arguments(4)
                                  myStampRows = arguments(5)
                                  Rem SET VALUES
                                  Rem ----------
                                  Dim myStampRows(3)
                                  If myMountLetter + myMountSize = "N10" Then
                                  myMountNumber = 21
                                  myLabelSize = "B"
                                  myStampCols = 3
                                  For I = 1 to 3
                                  myStampsRows(I) = 7
                                  Next
                                  End If
                                  Rem RETURN VALUES
                                  Rem -------------
                                  returnValue = cStr(myMountNumber) + vbTab + cStr(myLabelSize) + vbTab + cStr(myStampCols) + vbTab + cStr(myStampRows)
                                  • 14. Re: DoScript CS3 VB to VB
                                    Level 1
                                    you need to split array and add to "returnValue" - you should know what is the size of array ? ;)
                                    if array size could be dynamic - add it as last argument - first you will read/decode known number of "regular" params - all remaing elements will be an array
                                    robin
                                    • 15. Re: DoScript CS3 VB to VB
                                      Level 1
                                      I was afraid you would say that. Below is the code I'm working to move to a DoScript. I will have over 30 different scripts so I'm trying to have one master script for all, then a doscript for the data. I will not need dynamic arrays, but as you can see below I will have a lot of values (the number of myStampCols could be as large as 8), is there a limit to the number of values passed? Also I'm getting an error on the Dim statement if I use a variable (see the 2nd line below) for the array number value, what am I doing wrong? Maybe I'm doing this the wrong way, only a few of the stamps sizes have a different value per column, but I thought using an array was the best solution.
                                      Thanks again for all your help!
                                      Archie
                                      myStampCols = 2
                                      Dim myStampRows(myStampCols)
                                      Dim myStampStartX(3)
                                      Dim myStampStartY(3)
                                      Dim myStampWidth(3)
                                      Dim myStampHeight(3)
                                      Dim myStampHorizontalSpace(3)
                                      Dim myStampVerticalSpace(3)
                                      Dim myStampRotation(3)
                                      For I = 1 to 2
                                      If I = 1 Then
                                      myStampRows(I) = 2
                                      myStampStartX(I) = 52.035
                                      myStampStartY(I) = 82.973
                                      myStampWidth(I) = 38
                                      myStampHeight(I) = 63
                                      myStampHorizontalSpace(I) = 42.756
                                      myStampVerticalSpace(I) = 67.997
                                      myStampRotation(I) = -90
                                      Else
                                      myStampRows(I) = 3
                                      myStampStartY(I) = 91.211
                                      myStampWidth(I) = 63
                                      myStampHeight(I) = 38
                                      myStampVerticalSpace(I) = 42.651
                                      myStampRotation(I) = 0
                                      End If
                                      Next
                                      • 16. Re: DoScript CS3 VB to VB
                                        Level 1
                                        when you declare variable - bu using DIM - you need to specify number
                                        if you need to change size of array - you need to use ReDim
                                        when you join variables by converting to String - you build one item - string - but I don't know what is the limit of string passed as ReturnValue ;)
                                        robin
                                        • 17. Re: DoScript CS3 VB to VB
                                          Level 1
                                          Archie, I don't entirely follow what you're doing, but if you're using a stand-alone VB app, it would probably be easier to automate InDesign directly through the VB app, than call VBSCripts within InDesign. Look at my recent post for an example of how I'm doing it, and if you have any questions, I'll see if I can help.
                                          • 18. Re: DoScript CS3 VB to VB
                                            Level 1
                                            I think I have it working now. I'm using the DoScript to store data. I'm not using VB, just VBscript. I got around the array issue by putting them in a string with the pipe character as a separator. Then I use the split command to put them into arrays. How would I look at your recent post?
                                            Archie
                                            If myMountLetter + myMountSize = "N16" Then
                                            myMountNumber = "5"
                                            myLabelSize = "A"
                                            myLabelPercent =".48"
                                            myStampCols = "2"
                                            myStampRows = "0|2|3|"
                                            myStampStartX = "0|52.035|52.035|"
                                            myStampStartY = "0|82.973|91.211|"
                                            myStampWidth = "0|38|63|"
                                            myStampHeight = "0|63|38|"
                                            myStampHorizontalSpace = "0|42.756|42.756|"
                                            myStampVerticalSpace = "0|67.997|42.651|"
                                            myStampRotation = "0|-90|0|"
                                            End If
                                            myResultArray = Split(myDoScriptResult, vbTab)
                                            myMountNumber = myResultArray(0)
                                            myLabelSize = myResultArray(1)
                                            myLabelPercent = myResultArray(2)
                                            myStampCols = cInt(myResultArray(3))
                                            myStampRowsStr = myResultArray(4)
                                            myStampStartXStr = myResultArray(5)
                                            myStampStartYStr = myResultArray(6)
                                            myStampWidthStr = myResultArray(7)
                                            myStampHeightStr = myResultArray(8)
                                            myStampHorizontalSpaceStr = myResultArray(9)
                                            myStampVerticalSpaceStr = myResultArray(10)
                                            myStampRotationStr = myResultArray(11)
                                            myStampRows = Split(myStampRowsStr, "|")
                                            myStampStartX = Split(myStampStartXStr, "|")
                                            myStampStartY = Split(myStampStartYStr, "|")
                                            myStampWidth = Split(myStampWidthStr, "|")
                                            myStampHeight = Split(myStampHeightStr, "|")
                                            myStampHorizontalSpace = Split(myStampHorizontalSpaceStr, "|")
                                            myStampVerticalSpace = Split(myStampVerticalSpaceStr, "|")
                                            myStampRotation = Split(myStampRotationStr, "|")
                                            • 19. Re: DoScript CS3 VB to VB
                                              Level 1
                                              The subject of my post is "VB code for fitting graphics, deleting pages, updating TOC"
