7 Replies Latest reply on Aug 20, 2008 10:03 AM by (Helmut_Glunder)
    "Hide and show" for series of changes
      Although my question is a more general one: I actually use a Mac & Applescript.
      When applying a (scripted) series of operations to a graphics object, the sequence of operations is nicely visible. This is somehow funny to observe for a while but I should like to merely see the final result of the sequence of operations.
      A typical sequence consists of "frame shift"," frame crop" and "object centering".
      Is there a way to hide the display of the various actions and--after the sequence of operation has finished--to show the final result?
      Helmut
        • 1. Re: "Hide and show" for series of changes
          GagnonEric Level 1
          Have a look there:
          http://support.adobe.com/devsup/devsup.nsf/docs/50196.htm
          I never was able to make it work...
          Otherwise, the solution is Indesign Server for "headless" processing.
          • 2. Re: "Hide and show" for series of changes
            Level 1
            Thank you Eric for providing this interesting reference!
            In fact faceless documents don't perfectly apply to my situation in which the user has to interact with the contents of a document, i.e. select graphics objects. What I should like to see is suppressed re-drawing of selected graphics objects during a sequence of changes.
            Perhaps my computer is simply too slow so that a sequence of changes appears as distinct object positions and not as the final one...
            Thanks again
            Helmut
            • 3. Re: "Hide and show" for series of changes
              GagnonEric Level 1
              I'm not aware of any way to "lock" the redraw process, that would be a nice thing to have!
              I'm not sure if there could be a benefit performance wise or if it would answer a bit your needs, but you could try something like this wich would emulate a bit what you are looking for:
              Make every layer invisible
              do the processing
              Make every layer visible
              That should result in just one big blink. Knowing your object your could also just hide the specific item you are working on and show it back when the process is done.
              The only bad side is if you script crash for any reason (say, you forgot to handle a special case), that could leave the document in a undetermined state. For this, the layer hiding would be a better approach as the user can at least make the layer visible again through the interface (but could not on a page item basis). Depending on the processing that is done, often a revert is the best solution for a crashing script!
              ps: the headless mode look like a deprecated feature (in cs2/cs3?)... but strangely still is in the dictionary.
              • 4. Re: "Hide and show" for series of changes
                Level 1
                Eric,
                thank you for two really promising approaches to solving my little problem.
                I shall give both (layer and item hide & show) a try and report later on the results and further decisions.
                Thanks for your help!
                Best
                Helmut
                • 5. Re: "Hide and show" for series of changes
                  Level 1
                  Eric,
                  just to keep you informed:
                  Following a contribution of Martin Fischer to another thread ("Javascript show/hide the visibility of linked graphic layer") I was successful in hiding & showing the layer of a graphics object with frame "the_frame".
                  set visible of item layer of (the_frame) to false
                  do the processing
                  set visible of item layer of (the_frame) to true
                  The only drawback is, that my graphics object needs to be inline with the text thus resulting in a short blank of the whole page contents (text and graphics object are in the same layer). This however is at least as annoying as the sequence effect...
                  What I could not yet figure out is how to hide & show only the graphics item.
                  Any ideas of how to hide & show a single defined item?
                  Best
                  Helmut
                  • 6. Re: "Hide and show" for series of changes
                    GagnonEric Level 1
                    Have a look in dictionary if there is a visible attribute accessible for Page Item. I know there is the non-printing one, but that's for other purpose...
                    With most environnement, a typical trick to go against the lack of control on the screen update (aside double buffuring) is to move the objects offscreen.. say at position -10000, -10000. From what i remember i doesnt work with Indesign as you get the "object out of spread" error (unless i'm confusing with Quark!).
                    There maybe exist variation of the same idea... depending on the operation, you could make the boudings of the box to something like 0,0,1,1, do the transformation and bring the bounding box where it should be.
                    ps: Personnaly, i would not put as much effort on hidding the problem... is it because it's bothering you or your script users?
                    • 7. Re: "Hide and show" for series of changes
                      Level 1
                      Eric,
                      thanks for your never ending and excellent input!
                      In referring to: "Have a look in dictionary..."
                      Well, I searched it rather thoroughly but didn't find any promising keywords.
                      In referring to your postscriptum I agree:
                      The whole issue is one of aesthetics not function. The wiggling is not really bothering me but I tried at least to not confront users with it. Now that the discussed work-arounds won't considerably improve the situation I shall leave my code as is.
                      If you are interested to know what this is all about:
                      I nearly finished a suite consisting of three AS-apps (Mac OSX) that rather seamless integrate equation editing with MathType and "InDesign CS3". Presently, i'm in the phase of code polishing...
                      Thanks again and have a good day!
                      Helmut
