This content has been marked as final.
Show 4 replies
1. Re: CS2 Javascript crashing InDesign works as 2 parts and in CS3.
John.Kordas Aug 17, 2008 7:04 PM (in response to John.Kordas)//Here is the script.
var mySluglay, myBlueBlk, mySlugChr, mySlugPar, myPageNo, myTitle
myPageNo = 1;
myTitle = "Test";
myDocument = app.activeDocument;
function makeMyslug(){
//Create a layer for the slug items.
mySluglay = myDocument.layers.item("Slug");
if (mySluglay == null){
mySluglay = myDocument.layers.add({name:"Slug"});
//Create a blue background color.
myBlueBlk = myDocument.colors.item("BlueBack");
if (myBlueBlk == null){
myDocument.colors.add({name:"BlueBack", model:ColorModel.process, colorSpace:ColorSpace.cmyk, colorValue:[100, 60, 0, 0]});
//Create a cahr style.
mySlugChr = myDocument.characterStyles.item("SlugChar");
if (mySlugChr == null){
myDocument.characterStyles.add({name:"SlugChar", appliedFont:"Arial"});
//Create a para style.
mySlugPar = myDocument.paragraphStyles.item("SlugPar");
if (mySlugPar == null){
myDocument.paragraphStyles.add({name:"SlugPar"});
// Set units to mm.
app.activeDocument.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.MILLIMETERS
app.activeDocument.viewPreferences.verticalMeasurementUnits = MeasurementUnits.MILLIMETERS;
with(myDocument.documentPreferences){
//Slug
slugBottomOffset = "20";
slugTopOffset = "20";
slugInsideOrLeftOffset = "0";
slugRightOrOutsideOffset = "0";
//Set the documents ruler origin to page origin. This is very important
//--if you dont do this, getting objects to the correct position on the
//page is much more difficult.
myDocument.viewPreferences.rulerOrigin = RulerOrigin.pageOrigin;
//Create the slug details on all master pages.
with(myDocument.masterSpreads.item(0)){
myDocument.pages[0].appliedSection.continueNumbering = false;
myDocument.pages[0].appliedSection.pageNumberStart = parseInt(myPageNo);
var myDetails = "Title: "+myTitle;
var myPageWidth = myDocument.documentPreferences.pageWidth;
var myPageHeight = myDocument.documentPreferences.pageHeight;
mp = app.activeDocument.masterSpreads.everyItem().pages.everyItem().getElements();
for (i = 0; i < mp.length; i++){
var myTitleBox = mp[i].textFrames.add(myDocument.layers.item("Slug"), undefined, undefined, {geometricBounds:[myPageHeight+6,10,myPageHeight+14, myPageWidth-10], contents:myDetails});
myTitleBox.label = "Title";
myTitleBox.textFramePreferences.verticalJustification = VerticalJustification.bottomAlign;
myTitleBox.parentStory.paragraphs[0].appliedCharacterStyle = "SlugChar";
myTitleBox.parentStory.paragraphs[0].appliedParagraphStyle = "SlugPar";
myTitleBox.parentStory.fillColor = myDocument.swatches.item("Paper");
myTitleBox.parentStory.pointSize = 10;
myTitleBox.bringToFront();
myTitleBox.textFramePreferences.ignoreWrap = true;
myTitleBox.textFramePreferences.textColumnCount = 1;
var mycount = app.activeDocument.masterSpreads.item(0).pages.item(0).textFrames.item("Title");
var myBlueBlock = mp[i].textFrames.add(myDocument.layers.item("Slug"), undefined, undefined, {geometricBounds:[myPageHeight+6, 8,myPageHeight+20, myPageWidth-8]});
myBlueBlock.label = "BlueBlock";
myBlueBlock.fillColor = "BlueBack";
myBlueBlock.textFramePreferences.verticalJustification = VerticalJustification.bottomAlign;
myBlueBlock.sendToBack();
var myWhiteBlock = mp[i].textFrames.add(myDocument.layers.item("Slug"), undefined, undefined, {geometricBounds:[myPageHeight+14.5, 9,myPageHeight+19, myPageWidth-9]});
myWhiteBlock.label = "WhiteBlock";
myWhiteBlock.fillColor = myDocument.swatches.item("Paper");
var myPageNoBox = mp[i].textFrames.add(myDocument.layers.item("Slug"), undefined, undefined, {geometricBounds:[myPageHeight-5, 10, myPageHeight+18, myPageWidth-10]});
myPageNoBox.label = "PageNo";
myPageNoBox.insertionPoints.item(0).contents = SpecialCharacters.autoPageNumber;
myPageNoBox.insertionPoints.item(0).contents = SpecialCharacters.emSpace;
myPageNoBox.insertionPoints.item(0).contents = "Page No";
myPageNoBox.parentStory.paragraphs[0].appliedCharacterStyle = "SlugChar";
myPageNoBox.parentStory.paragraphs[0].appliedParagraphStyle = "SlugPar";
myPageNoBox.textFramePreferences.verticalJustification = VerticalJustification.bottomAlign;
myPageNoBox.textFramePreferences.ignoreWrap = true;
myPageNoBox.textFramePreferences.textColumnCount = 1;
//print function
function printMyslug(){
alert("Start print process.");
myDocument.printPreferences.printer = Printer.POSTSCRIPT_FILE;
myDocument.printPreferences.ppd = PPDValues.DEVICE_INDEPENDENT;
for(var myCounter = 0; myCounter < myDocument.pages.length; myCounter++){
myPageName = myDocument.pages.item(myCounter).name;
myDocument.printPreferences.pageRange = myPageName;
//The name of the exported files will be the base name + the page name + ".pdf".
//If the page name contains a colon (as it will if the document contains sections),
//then remove the colon.
var myRegExp = new RegExp(":","gi");
myPageName = myPageName.replace(myRegExp, "_");
myFilePath = "/c/idjavascript/test_" + myPageName + ".ps";
myFile = new File(myFilePath);
document.printPreferences.printFile = myFile;
try{
myDocument.print(false);
catch(e){
alert("Page "+myPageName+" may be blank plesae check.");
//call the makeMyslug function
makeMyslug();
//call the printMyslug function
printMyslug(); -
2. Re: CS2 Javascript crashing InDesign works as 2 parts and in CS3.
try67 Aug 18, 2008 1:30 AM (in response to John.Kordas)What do you mean by "crashes"? Is there any error message, or does it simply exit? -
3. Re: CS2 Javascript crashing InDesign works as 2 parts and in CS3.
John.Kordas Aug 18, 2008 3:47 PM (in response to John.Kordas)The error I get is:
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: C:\Program Files\Adobe\Adobe InDesign CS2\InDesign.exe
This application has requested the Runtime to terminate it in an unusale way. Please contat the application's support team for more information.
Once I click OK the InDesign is gone. -
4. Re: CS2 Javascript crashing InDesign works as 2 parts and in CS3.
John.Kordas Aug 24, 2008 4:26 PM (in response to John.Kordas)The only thing I found that stop the script crashing InDesign was to comment out the myDocument.print(false) and put in an alert to check if the path was correct and it works.
I have a feeling that the print process may be trying to execute before the slug area is created.
Can anyone suggest a way to check that one function or part of the script is complete before the second part starts?
