2 Replies Latest reply on Sep 25, 2008 4:47 AM by (Dave_Saunders)
    CS3 JS Add group into frame
      Hi
      In InDesign UI you can copy a group of frames and paste it into another frame.
      I'm trying to replicate the results via JS
      I tried this:
      x = app.activeDocument.rectangles.add();
      y = app.activeDocument.ovals.add();
      z = app.activeDocument.ovals.add();
      x.groups.add([y,z]);
      then this:
      x.groups.add([app.activeDocument.ovals.add(),app.activeDocument.ovals.add()]);
      Both attempts ended up with "Invalid parameter" error message
      Then I tried this:
      g = app.activeDocument.groups.add([y,z]);
      g.select();
      app.cut();
      x.select();
      app.pasteInto();
      It did the job without errors, but I'm affraid it will be unnecessary slow in real world deployment.
      Please, can anyone explain what I did wrong with my first two attempts?
      Thanks for help
      Weller
        • 1. Re: CS3 JS Add group into frame
          Level 1
          Hi
          Having carried out more experiments I made this discovery:
          (assuming that "myObject is a rectangle")
          after running:
          myObject.rectangles.add();
          I ended up with a couple of rectangles inside of the "myObject" frame.
          But they were not grouped.
          Though this partly solves my problem, I'm aware that Indesign won't allow me to do this in UI. (That is, it's only a single object or a group that can be "pasted into"). Am I really in for a big problem if I use this method?
          • 2. Re: CS3 JS Add group into frame
            Level 1
            Actually, although the UI won't let you create such an object, it does support them. Objects that start life as Excel charts have exactly this structure. Take them into Illustrator then copy and paste into InDesign and you'll find you have objects that are exactly what you've discovered.
            See: http://indesignsecrets.com/easily-add-captions-to-graphics-frames.php
            Dave
