2 Replies Latest reply on Oct 14, 2008 6:18 AM by (kwilson68)
    Batch Flow
      I am trying to find a script that can batch flow MS Word documents into an InDesign CS3 template on Windows. What I would like the script to do is open the template, autoflow one MS Word document into the template, save the template with a new file name (same name as the MS Word file but with the indd extension), and then close the document. I would like it to be able to do this for every MS Word document in a directory.
      Does anyone know if a script like this is available?
        • 1. Re: Batch Flow
          Level 1
          by "template" - you mean INDD document with prepared TextFrame for text or MS Word document should be autoflowed inside margins ?
          robin
          www.adobescripts.com
          • 2. Re: Batch Flow
            Level 1
            I mean an INDD document that has already been set up as a template. The script should select the left column text frame and begin flowing there. The right hand column is already set up a well. The script should use autoflow, so that InDesign automatically adds pages as needed based on the master page.
