0 Replies Latest reply on Oct 16, 2008 5:40 AM by (Lachlan_Hardy)
    Dynamic url's - XML (data and image) integration
      I am trying to setup an InDesign template which can map xml data to certain tables and fields. Each template will be calling on many xml files.
      The xml files are called using a url which is dynamic. I.E. once logged into the service which provides the xml, the url that you use to call the data has a section which is a "session id" - which changes day to day.
      Is there any work being done, or already done in integrating this kind of xml?
      Ultimately I am aiming at simply "running" a service which will import all the data fields from multiple xml files and place them all in the correct places.
      Then I will PDF the thing - surely there are similar things going on?
      Regards
      L
