3 Replies Latest reply on Oct 29, 2008 5:20 AM by Polarbeer101
    Coordinates in InDesign
    Polarbeer101
      Hi!
      Is it possible to get coordinates for a specific element in InDesgin?
      I need the coordinates on a page for example a tagged word or image.
      Regards,
      Lars
        • 1. Re: Coordinates in InDesign
          Level 1
          Yes.
          For page items, use geometric bounds (or visible bounds).
          For text, use baseline and horizontal offset.
          Dave
          • 2. Re: Coordinates in InDesign
            Level 1
            you need to use GeometricBounds:
            Property GeometricBounds As Variant
            Member of InDesign.Rectangle
            The bounds of the Rectangle excluding the stroke width, in the format [y1, x1, y2, x2], which give the coordinates of the top-left and bottom-right corners of the bounding box. as Array of 4 Units (Doubles or Strings)
            and this is easy for graphics objects - rectangle, image, oval, textframe, etc.
            for text - you need to play with Baseline and HorizontalOffset:
            Property Baseline As Variant
            read-only
            Member of InDesign.Text
            The vertical offset of the text. as Unit (Double or String)
            Property HorizontalOffset As Variant
            read-only
            The horizontal offset of the text. as Unit (Double or String)
            robin
            www.adobescripts.com
            • 3. Re: Coordinates in InDesign
              Polarbeer101 Level 1
              Thanks for the replies, I'll check it out.
