9 Replies Latest reply on Feb 3, 2011 3:19 PM by Lev Ger
    getting the page of a link
      hello forum
      I use applescript to automate indesign.
      now I've to do a job, where I make textframes on a new layer, same size and position as image/grafic-objects on other layers.
      to do this, I check the links of the document. if there are more than one page, I need the page-number/id to position my textframe.
      I've tried a lot of things to find out the page of a link, but nothing is perfect.
      does anybody know an absolutly sure way to get the page number of a link - for example the to get the number in the link palette of the application.
      InDesign CS3 on Mac OS X 10.4.11
      thank you in advance.
        • 1. Re: getting the page of a link
          Kasyan Servetsky Level 5
          Here is my way of finding where the link is. I had to fall back upon JavaScript. But it doesn’t work for inline graphics; I just didn’t need it.
          on whereIsTheLink(theLink)
          tell application "Adobe InDesign CS3"
          set myLinkIndex to index of theLink
          set myJsScript to "#target indesign
          myDoc = app.activeDocument;
          myLink = myDoc.links[ \"" & myLinkIndex & "\" – 1];
          myMessage = whereIsTheLink(myLink);
          function whereIsTheLink(theLink){
          while (theLink.constructor.name != 'Application') {
          theLink = theLink.parent;
          myHierarchy += theLink.constructor.name + '|';
          if (myHierarchy.lastIndexOf('|Character|Story|Document|Application|') != -1)
          return 'inline object';
          else if (myHierarchy.lastIndexOf('|Page|MasterSpread|Document|Application|') != -1)
          return 'master page';
          else if (myHierarchy.lastIndexOf('|MasterSpread|Document|Application|') != -1)
          return 'pasteboard of master page';
          else if (myHierarchy.lastIndexOf('|Page|Spread|Document|Application|') != -1)
          return 'page';
          else if (myHierarchy.lastIndexOf('|Spread|Document|Application|') != -1)
          return 'pasteboard';
          • 2. Re: getting the page of a link
            P.S. Once you know that the link is on a page, you can easily find the page name (aka page number). Take note that this function works for images nested in groups (no matter how deep).
            #target indesign
            myLink = myDoc.links[0];
            alert("My link is on " + myMessage);
                  if (theLink instanceof Page) {
                     var myPageName = theLink.name;
                  return 'page ' + myPageName;
            • 3. Re: getting the page of a link
              Here I wrote a new function, which returns the page number for inline graphics too.
              #target indesign
              if (!isNaN(parseInt(myMessage))){
                 myMessage = 'page ' + myMessage;
                       return myPageName;
                    if (theLink instanceof Character) {
                       var thePage = whereIsTheLink(theLink.parentTextFrames[0]);
                       if (thePage != undefined) return  thePage;
              • 4. Re: getting the page of a link
                Level 1
                dear kasyan
                thanks a lot for your info.
                so this means, also js cannot grab the page/page nr. directly.
                I use this handler/function in as:
                on myPageChecker(myObject)
                set myTemp to parent of myObject
                repeat while class of myTemp ≠ page
                if class of myTemp ≠ story then
                set myTemp to parent of myTemp
                else
                set myTemp2 to item 1 of text containers of myTemp
                repeat while class of myTemp2 ≠ page
                set myTemp2 to parent of myTemp2
                end repeat
                return id of myTemp2
                end if
                end repeat
                return id of myTemp
                end tell
                end myPageChecker
                works fine - also for inline graphics.
                just hoped there might be a "hidden feature" to get the page property directly.
                • 5. Re: getting the page of a link
                  Level 1
                  this might look better...
                  else
                  end repeat
                  end if
                  end repeat
                  return id of myTemp
                  end tell
                  end myPageChecker
                  • 6. Re: getting the page of a link
                    (Simon_Paterson) Level 1
                    Not sure if this is of any help to you now. I find this function to be reliable because it deals with images of any type, grouped, inline or otherwise, as well as those on masterpages. (If your images are never on a masterpage, then you can simply remove that part of the function, which makes this quite compact.) Hope this helps.
                    >on GetPageOfLink(theLink)
                    tell document 1
                    set theLinkId to id of theLink
                    -- Image on normal document page
                    repeat with p from 1 to (count of pages)
                    tell page p
                    set theGraphicsLinksIDs to (id of item link of all graphics) as list
                    if theLinkId is in theGraphicsLinksIDs then return id
                    end tell
                    end repeat
                    -- Image on master page
                    repeat with ms from 1 to (count of master spreads)
                    repeat with mp from 1 to (count of pages of master spread ms)
                    tell page mp of master spread ms
                    end tell
                    end repeat
                    end repeat
                    end tell
                    end tell
                    end GetPageOfLink
                    • 7. Re: getting the page of a link
                      Lev Ger Level 1
                      Dear Kasyan,
                      Your function for getting the page number of a link was working great for me, but it no longer works with CS5. I have tried to tweak it, but have been unsuccessful, I believe it is something to do with the introduction of the "parentPage" property to page items in CS5. I would appreciate your help to get your function to work for both CS4 and 5.
                      Thanks in advance.
                      • 8. Re: getting the page of a link
                        Harbs. Level 6
                        Try replacing this:
                        with something like this:
                        if(theLink.hasOwnProperty("parentPage")){
                            theLink = theLink.parentPage;
                        } else {
                        Harbs
                        • 9. Re: getting the page of a link
                          Lev Ger Level 1
                          Thank you for your awesome solution!
                          It worked with a slight amendment:
                          if(theLink.hasOwnProperty("parentPage") && theLink.parentPage != null){
                          } else {
                          I added the " && theLink.parentPage != null", otherwise theLink is set to null if the frame is on the pasteboard.
                          This works for CS4 and CS5!
                          Thanks again!
