11 Replies Latest reply on Feb 25, 2009 12:58 AM by bART2007
    Export SWF with transparent background
    bART2007
      I want to generate a SWF with a transparent background from an InDesign document.
      Exporting to SWF is working fine, but since the default Paper swatch is white, my exported SWFs have, by default, a white background.
      I cannot find out how I can set the default Paper swatch to 'None' or transparent. Or maybe there is another way to obtain the same result.
      Any help is greatly appreciated because this is a blocking issue for me.
      Chris.
        • 1. Re: Export SWF with transparent background
          Loic.Aigon Adobe Community Professional
          And you want to do that by scripting ?
          Paper is opaque by nature. A transparent frame is "filled" with None or a swatch with 0% opacity. But you already know this.
          Did you make any search in the help or in google ?
          Loic
          • 2. Re: Export SWF with transparent background
            bART2007 Level 1
            I agree that paper is opaque by nature :-), but it's not unusual in the printing industry to print on transparent materials, so I think there must/should be a way to do this.
            Chris.
            • 3. Re: Export SWF with transparent background
              Telling InDesign you will print on a transparency sheet will not make the screen transparent.
              InDesign itself sets nothing as 'background', so if you print on paper, you get a white background ... and on a transparency sheet, you will get /no/ background.
              What Loic was pointing out is that the background appears to be a function of the SWF export, and you cannot change it by scripting.
              • 4. Re: Export SWF with transparent background
                bART2007 Level 1
                Thanks for pointing this out. I really thought the paper swatch/color was used as background for the swf export, but I did some tests and it isn't.
                So, why is the background always white when exporting to swf?
                • 5. Re: Export SWF with transparent background
                  That was smart thinking. So it is NOT the [Paper] swatch colour -- not exactly what I was expecting.
                  Why indeed.
                  Ask me why the sky is blue and I can tell you.
                  • 6. Re: Export SWF with transparent background
                    Ildhund Level 3
                    Black? [Paper] means absence of ink; since SWF is only viewed on a
                    screen, it could be that the equivalent to transparent would be
                    absence of light, i.e. Black. Just a thought.
                    Noel
                    • 7. Re: Export SWF with transparent background
                      i So, why is the background always white when exporting to swf?
                      I think that Indesign ability to export as swf has more to be considered as a cool tool, useful once in a while, than a real productive tool.
                      Indesign is probably not a multimedia creation software as Flash.
                      Once that said, you may try to import this exported swf into flash if you have this soft. You have to create a new document and place the swf in the scene.
                      There is chance that you get all the elements rasters and vectors. Hence, you will be able to set the background as transparent I guess.
                      certainly much more cumfortabily.
                      Loic
                      PS: At last, you my request this improvement in Indesign new versions. Adobe offers a page for that kind of wishes.
                      • 8. Re: Export SWF with transparent background
                        i but it's not unusual in the printing industry to print on transparent materials
                        You are right but in this case, a "paper" background is a mental concept. In indesign, it simulates the render of the medium. It's not a ink.
                        You can have a "paper" background set to blue. It won't mean you will export blue datas but it helps the designer to make his layout based on the colored paper onto which it will be printed.
                        "Paper" looks white because most of the time, jobs are printed onto white paper. But once again, this is not a real data but a help.
                        You can have a white paper background but when you will print on a transparent media, there won't be any white ink on it.
                        • 9. Re: Export SWF with transparent background
                          bART2007 Level 1
                          Loic,
                          I totally follow your reasoning about paper color and ink ...
                          Concerning the SWF, I'm not scripting against InDesign, but programming (in Java) against InDesign Server. I already posted my question on the InDesign Server forum a couple of weeks ago, but without response.
                          It is pretty important for the tool I'm making that the SWF background is transparent since our Flex client will have to put different SWFs on top of each other thereby taking transparancy into account.
                          Anyway, thanks for the feedback. I will contact Adobe and post a feature/improvement request.
                          • 10. Re: Export SWF with transparent background
                            Hi, it is possible to make background transparaent but how! look at this is is realy nice.
                            http://demo.quietlyscheming.com/book/Anatomy.html
                            Please if you found the answer, it would be nice to publish it here.
                            • 11. Re: Export SWF with transparent background
                              bART2007 Level 1
                              The anatomy example is very nice, but I'm not sure that the different drawings are generated by InDesign.
                              I managed to get this question to the Adobe InDesign Server development team, and they replied that it's NOT possible to export a SWF with a transparent background in CS4. They advised me to post a feature request for CS5.
