4 Replies Latest reply on Jan 22, 2009 12:20 AM by Loic.Aigon
    Import XML [JS]
    Rajeev Kumar MIL Level 1
      Hi all,
      I am trying to import XML file into chosen template, please see below. I am not able to import XML file, please help me. After importing I want to save the indesign document on the location of XML file.
      var FilterID = "InDesign Template: *.indt";
      var FilterXML = "XML File: *.xml";
      var myFile = File.openDialog("Please choose InDesign Template", FilterID);//To choose InDesign template
      var myXML = File.openDialog("Please choose XML File", FilterXML);
      app.scriptPreferences.userInteractionLevel = UserInteractionLevels.neverInteract;
      var myDoc = app.open(myFile);
      //app.importXML(myFIle, myXML);
        • 1. Re: Import XML [JS]
          Loic.Aigon Adobe Community Professional
          Start trying this :
          import into doc rather than app
          You mistyped myFile (myFIle)
          app.activeDocument.importXML(myFile, myXML);
          • 2. Re: Import XML [JS]
            Change
            to
            myDoc.importXML(myXML);
            Lin
            > -----Original Message-----
            > From: rajeevkumar [mailto:member@adobeforums.com]
            > Sent: Wednesday, January 21, 2009 4:45 AM
            > To: adobe.scripting.indesign@adobeforums.com
            > Subject: Import XML [JS]
            > A new discussion was started by rajeevkumar in
            > InDesign Scripting --
            > Import XML [JS]
            > Hi all,
            > Thanks
            > ________________________________
            > View/reply at Import XML [JS]
            > Replies by email are OK.
            > Use the unsubscribe
            form
            > to cancel your email subscription.
            • 3. Re: Import XML [JS]
              Hi All,
              Thanks, I have already done that. Now I want to save InDesign document. at present if I am saving the file then it shows .xml.indd I want to remove .xml from the file name while saving.
              var myXMLName = myXML.fielName;
              myDoc.xmlElements.item(0).importXML(File(myXML));
              if(app.activeDocument.saved == false)
              app.activeDocument.save(new File(myXML+".indd"));
              • 4. Re: Import XML [JS]
                Hi
                I use this approach but they may be a better way :
                var myXMLFolder = File(myXML).parent;
                var myXMLName = myXML.name;
                app.activeDocument.save(new File(myXMLFolder+"/"+myXMLName.split(".xml")[0]+".indd"));
                //myXMLName.split(".xml")[0] return first part of the name
                //I can't do myXML.split(".xml") so I had to reconstruct the path
                //Hence I needed to know the file parent folder.
