1 Reply Latest reply on Jan 28, 2009 1:18 PM by (mps)
    Relink Data Merge using Find
      The script I am using imports XML then merges records. I need the two different input files (even though this seems counter intuitive) because of the groups of people they come from.
      I want to write a line to find a merge tag and relink it to the source.
      example:
      <<new800number>>
      I can't separate it from the XML because it is part of the layout that will need to flow with changing copy length.
      I searched the forum but didn't find anything, could someone point me in the right direction? I hope I have supplied enough detail.
      Many Thanks! -M
        • 1. Re: Relink Data Merge using Find
          Level 1
          So I found a solution. I put the Data Merge line before the import XML line and the XML (though containing info about the merge fields) did not overwrite the input from the Data Merge.
          for(myDocumentCounter = app.documents.length; myDocumentCounter > 0; myDocumentCounter--){
          app.activeDocument.dataMergeProperties.mergeRecords();
          app.activeDocument.importXML(myXML);
          Out of curiosity, why?
          And would this be the right path toward the original relink question? What would this be missing.
          (find text preferences:{find what:"<<a800number>>"}, relink);
          -M
