5 Replies Latest reply on May 28, 2009 10:46 PM by John.Kordas
    #targetengine "session"
    Level 1
      Hi All,
      I have placed a script with menu items in de Startup Scripts folder.
      The uncompiled version works fine, the binary doesn't.
      I get a message that the object does not longer exist with the binary version.
      It must have something to do with #targetengine "session".
      Is there a solution for this?
      Thanks Michel
        • 1. Re: #targetengine "session"
          Level 1
          By the way, I use CS3 and javascript on the mac.
          • 2. Re: #targetengine "session"
            Level 1
            I think that's a limitation. I seem to remember reading about it here before. Can you work around it by having your binary script write a script to a temporary file, run it with a doScript and then delete the temporary file? That might work.
            • 3. Re: #targetengine "session"
              Level 1
              I found what the problem is.
              Binary scripts can't switch to a specific script engine.
              The solution is in the menuitem loader samplescripts
              in de scripts folder of CS3 and CS4.
              • 4. Re: #targetengine "session"
                John.Kordas Level 1
                I've just come across the same issue. If anyone can tell me which of the examples in the menus folder to look at that would be great.
                Cheers, John.
                • 5. Re: #targetengine "session"
                  John.Kordas Level 1
                  This simple script works as a jsx file but as soon as you export it as a jsxbin it does not work. Any suggestions?
                  var myDialog = new Window('palette','Starting Pg No');
                      myDialog.dPgNo = myDialog.add('panel',undefined,'File details');
                      myDialog.dPgNo.alignChildren = 'left';
                      myDialog.dPgNo.myPgNo = myDialog.dPgNo.add('group');
                      myDialog.dPgNo.myPgNo.myGroup = myDialog.dPgNo.myPgNo.add('group');
                      myDialog.dPgNo.btnGroup = myDialog.dPgNo.add('group');
                      with (myDialog.dPgNo){
                          myPgNo.myGroup.orientation = 'column';
                          myPgNo.myGroup.alignChildren = 'right';
                          myPgNo.myGroup.preferredSize = [90,15];
                          myPgNo.myGroup.st  = myPgNo.myGroup.add('statictext',undefined,'Your Doc starting page is:');
                          myPgNo.et = myPgNo.add('edittext', undefined, app.activeDocument.pages[0].name)
                          btnGroup.btn = btnGroup.add('button', undefined, 'Update');
                          btnGroup.alignment = 'right';
                  myDialog.dPgNo.btnGroup.btn.onClick = function() {
                      var myPagestart = myDialog.dPgNo.myPgNo.et.text;
                      if (app.activeDocument.pages[0].name != myPagestart){
                          app.activeDocument.pages[0].appliedSection.continueNumbering = false;
                          app.activeDocument.pages[0].appliedSection.pageNumberStart = parseInt(myPagestart);
                          app.activeDocument.pages[0].appliedSection.sectionPrefix = "";
                          alert("Your document start page has been changed to "+myPagestart+".");
