3 Replies Latest reply on Jan 25, 2009 7:57 PM by Newsgroup_User
    Confused on Override Function and "set" method ??
    WestSide Level 1
      I am creating this itemRenderer for my tree control. I am learning from some examples and I wanted to know if someone can explain this code and specifically where it gets the value that you pass in to the function. I am not calling this function explicitly so can someone explain:
      1. How and when it gets called?
      2. How do you pass data in since I am not calling it explicitly
      public class MyRenderer extends TreeItemRenderer {
      override public function set data(value:Object):void {
      super.data = value;
      I understand it is setting the "data property" but still unclear on my questions above.
      Any help appreciated.
      -Westside
        • 1. Re: Confused on Override Function and "set" method ??
          Level 7
          "WestSide" <webforumsuser@macromedia.com> wrote in message
          news:glgnh9$cuc$1@forums.macromedia.com...
          > Hi,
          > some
          > specifically
          > calling
          > super.data = value;
          > questions above.
          There is no value in overriding set data() in this way unless you are _also_
          doing something else in here, since essentially what this says is to pass
          the value variable through to the original data property on the original
          class.
          Typically, what I do is something more like this:
          private var _dataChanged:Boolean=true;
          private var _data:Object;
          if (value != _data) {
          _data = value;
          super.data = value;
          _dataChanged = true;
          //something has changed, schedule a call to commitProperties
          invalidateProperties();
          override protected function commitProperties():void {
          //make sure to run the existing commitProperties!
          super.commitProperties();
          //now set whatever needs to be set based on what changed
          if (_dataChanged && data.hasOwnProperty('someValue')) {
          myLabel.text = data['someValue'];
          HTH;
          Amy
          • 2. Re: Confused on Override Function and &quot;set&quot; method ??
            WestSide Level 1
            Thanks for the reply, this makes more sense now.
            -Westside
            • 3. Re: Confused on Override Function and &quot;set&quot; method ??
              Level 7
              news:glj8rm$grm$1@forums.macromedia.com...
              > Hi,
              You're welcome. You may want to check out the links for Q2:
              http://www.magnoliamultimedia.com/flex_examples/Amys_Flex_FAQ.pdf
