4 Replies Latest reply on Feb 4, 2009 5:37 PM by dhishok
    Find some characters and replace with character style...
    dhishok Level 1
      Hi everyone,
      The below script is to find some space characters and replacing with character style. Its working fine with InDesignCS2 MAC.
      //InDesign CS2//
      with(app.activeDocument){
      myNewCharStyle = characterStyles.add();
      with(myNewCharStyle){
      name= "x"
      fontStyle = "Roman"
      app.findPreferences = null;
      app.changePreferences = null;
      myDoc.search("^>", false, false, undefined, undefined, {appliedCharacterStyle:"x"});
      myDoc.search("^m", false, false, undefined, undefined, {appliedCharacterStyle:"x"});
      Now i am currently working in InDesignCS3, and i have also changed the script somewhat but its not working with CS3 MAC...
      //InDesign CS3//
      if (myDoc.characterStyles.item ('x') == null)
      myDoc.characterStyles.add ({name: 'x'});
      var myNewCharStyle = myDoc.characterStyles.item ('x');
      name= "x"
      fontStyle = "Roman"
      function setupFindText(myFindTextPreferences, myChangeTextPreferences, myNewCharStyle) {
      app.findTextPreferences = null;
      app.changeTextPreferences = null;
      app.findTextPreferences.findWhat = "^>";
      app.changeTextPreferences.appliedCharacterStyle = myNewCharStyle;
      app.findTextPreferences.findWhat = "^m";
      can anyone help me for this. Thanks in advance.
      Regards
      Thiyagu
        • 1. Re: Find some characters and replace with character style...
          Level 1
          Hi Thiyagu,
          You're not telling InDesign CS3 to do anything here:
          You've set the find and change text preferences, but you haven't issued a command to change the text. What you need looks something more like this:
          //Add a line to perform the change:
          app.documents.item(0).changeText();
          It's also not clear to me that this will work:
          I think that this will always be true, even if the style does not exist.
          Ole
          • 2. Re: Find some characters and replace with character style...
            dhishok Level 1
            Hi Ole,
            Thanks for your kind support. Actually what i need is, find en space & em space characters in the InDesign CS3 document and apply character style for those characters. I have tested your script also its running but not performing the change action. Please look into this and help for this.
            Regards
            Thiyagu
            • 3. Re: Find some characters and replace with character style...
              Level 1
              Hi Thiyagu,
              If it's not working, it's most likely that the character style does not exist, or, if it does exist, it's inside a style group. Could that be the problem?
              Ole
              • 4. Re: Find some characters and replace with character style...
                dhishok Level 1
                Hi Ole,
                What you said is correct. I am creating the character style but it is not inside the style group. Then finding those characters and apply character style for it. Unfortunately the find & change process defined as a function, then only it doesn't run properly. Now below script is working fine.
                name= "x"
                fontStyle = "Roman"
                Regards
                Thiyagu
