2 Replies Latest reply on Feb 8, 2009 10:22 AM by EliotHarper
    Migrating scripts to InDesign Server
    EliotHarper
      Hello,
      Could someone explain what the process is to migrate a JavaScript InDesign script so that it can be used by InDesign Server? From reading the server documentation, I understand that I can run scripts from the TestClient command-line tool, but what changes do I need to make the the script? Do I simply need to change the #target name (if so, to what?) and are there other differences that I need to be aware of?
      Eliot
        • 1. Re: Migrating scripts to InDesign Server
          Level 1
          Hi Eliot,
          In all the work I've done with InDesign Server, I've never given a moments thought to the #target command. I think that's largely because in my case, I've been working with Typefi Publish and it launches my scripts and they are by definition targeted to ID Server.
          Within the scripts, there's quite a lot to look out for. Nearly all UI-related stuff is unavailable. So, for example, there is no such thing as
          app.activeDocument
          in ID server. That's one of the reasons I use app.documents[0] in all my scripts, whether for server or desktop. Similarly, anything related to windows is unavailable and will cause errors.
          If you have ESTK installed on a machine with InDesign Server, you should be able to see its object model in the Object Model Viewer under ESTK's Help menu.
          Dave
          • 2. Re: Migrating scripts to InDesign Server
            EliotHarper Level 1
            Thanks Dave, I'll give it a whirl...
