This content has been marked as final.
Show 4 replies
1. Re: CS3 JS Radio button layout
pkahrel Feb 9, 2009 1:18 AM (in response to John.Kordas)With scriptUI, yes.
Peter -
2. Re: CS3 JS Radio button layout
John.Kordas Feb 9, 2009 2:59 PM (in response to John.Kordas)Thanks Peter,
Did a bit of a search on scriptUI and found a couple by Dave Sanders.
In his example he codes the dialog;
myDlg = new Window('dialog', 'Drop-down List');
myDlg.orientation = 'column';
myDlg.alignment = 'right';
//add drop-down
myDlg.DDgroup = myDlg.add('group');
myDlg.DDgroup.orientation = 'row';
The test I was working on is as follows:
function myDisplayDialog(){
var myDialog = app.dialogs.add({name:"Radio layout"});
//Add a dialog column.
with(myDialog.dialogColumns.add()){
var myRadioButtonGroup = radiobuttonGroups.add();
with(myRadioButtonGroup){
var myFirst = radiobuttonControls.add({staticLabel:"One", checkedState:true});
var mySecond = radiobuttonControls.add({staticLabel:"Two"});
//Show the dialog box.
var myResult = myDialog.show();
myDisplayDialog();
So is it possible to do somthing like:
with(myRadioButtonGroup.orientation = "row" ){
or should i be following the format Dave has in his example? -
3. Re: CS3 JS Radio button layout
pkahrel Feb 9, 2009 9:37 PM (in response to John.Kordas)John,
Dave's example is scriptUI, yours uses InDesign's dialog system. The latter doesn't let you organise buttons in rows, you have to use scriptUI. Here's your example in scriptUI:
var myDialog = new Window ('dialog', "Radio layout");
var rg = myDialog.add ('group')
var rb1 = rg.add ('radiobutton', undefined, 'Button 1');
rb1.value = true;
var rb2 = rg.add ('radiobutton', undefined, 'Button 2');
myDisplayDialog();
scripUI's documentation is in the ESTK: Help > SDK > JavaScript's Toolguide CS3. scriptUI's object model is at Help > scriptUI classes.
Peter -
4. Re: CS3 JS Radio button layout
John.Kordas Feb 9, 2009 9:57 PM (in response to John.Kordas)Thanks Peter,
That's what I was after.
Much appreciated.
