1 Reply Latest reply on Feb 17, 2009 2:08 PM by sstanleyau
    [AS CS3] Another MathType Baseline Shift Question
    marcusstringer Level 3
      Hi Guys,
      I am using the below script to place MathType Equations into an InDesign File
      Basically it searches for tags <<Filename.eps>> and replaces it with a inline graphic.
      My question is:
      Is there anyway I can get it to read the height of the InLine Graphic Box and then get it to baseline shift so it's centered height wise on the line, instead of the set amount of -10pt that is uses now?
      We have to open the MathType Equations in Illustrator to change font and colour to Pantone etc, so they are save back as Illustrator EPS's
      Below is the Script:
      tell application "Adobe InDesign CS3"
      tell document 1
      set baselineVar to "Yes"
      set countVar to 0
      set imageCount to 0
      set docPath to file path as alias
      tell application "Finder"
      set imageFolder to folder (choose folder with prompt "Please choose the folder containing the appropriate MathType files") --"MathType" of artFolder
      end tell
      activate
      set allStories to stories
      repeat with s from 1 to count of items of allStories
      set theStory to item s of allStories
      if class of theStory is story then
      set theLim to count of words of theStory
      try
      repeat with i from 1 to theLim
      if word i of theStory contains "<<" then
      set theText to contents of word i of theStory as Unicode text
      set theOffset to (offset of "<<" in theText)
      set endOffset to (offset of ">>" in theText)
      set imageName to characters (theOffset + 2) through (endOffset - 1) of theText as string
      set imageFolderPath to ((imageFolder as string) & imageName)
      set wholeTag to characters theOffset through (endOffset + 1) of theText as string
      if baselineVar = "Yes" then
      set baseline shift of characters theOffset through (endOffset + 1) of word i of theStory to -10.2
      end if
      delete characters theOffset through (endOffset) of word i of theStory
      tell theStory
      tell word i
      tell character theOffset
      place imageFolderPath as alias
      set countVar to (countVar + 1)
      end tell
      end tell
      end tell
      end if
      end repeat
      end try
      end if
      end repeat
      end tell
      activate
      if countVar = 0 then
      display dialog "No Images were found" buttons "OK" default button 1 with icon 2
      else if countVar = 1 then
      display dialog "1 lonely Images has been placed." buttons "OK" default button 1
      else
      display dialog (countVar as string) & " Images have been placed." buttons "OK" default button 1
      end if
      end tell
      Marcus
