9 Replies Latest reply on Mar 28, 2008 6:50 AM by Kasyan Servetsky
    How to call javascript using applescript in InDesign cs2 Mac
    subhaoviya Level 1
      I need to integrate javascript with my apple script??? how to use it???please help me...i need it immediately..........
        • 1. Re: How to call javascript using applescript in InDesign cs2 Mac
          Kasyan Servetsky Level 5
          Hi subhaoviya,
          Use do javascript command, below is an example.
          Kasyan
          on manualUnsharp(amount1, radius1, threshold1, amount2, radius2, threshold2)
          tell application "Adobe Photoshop CS2"
          set myManualUnsharpScript to "
          #target photoshop
          app.bringToFront ();
          var docRef = activeDocument;
          makeUnsharpLayer() ;
          manualUnsharp( arguments[0], arguments[1], arguments[2] );
          manualUnsharp( arguments[3], arguments[4], arguments[5] );
          function makeUnsharpLayer() {
          if (docRef.layers.length > 1) {
          for ( j = docRef.layers.length – 1; j > 0; j— ) {
          if (docRef.layers[j].visible == false) {
          docRef.layers[j].remove();
          docRef.mergeVisibleLayers();
          var myMergedLayer = docRef.activeLayer;
          var mySharpLayer = docRef.activeLayer.duplicate(docRef.layers[0], ElementPlacement.PLACEBEFORE);
          mySharpLayer.name = 'Unsharp Mask Layer';
          docRef.activeLayer = mySharpLayer;
          myMergedLayer.visible = false;
          function manualUnsharp( amount, radius, threshold ) {
          var id29 = charIDToTypeID( 'UnsM' );
          var desc10 = new ActionDescriptor();
          var id30 = charIDToTypeID( 'Amnt' );
          var id31 = charIDToTypeID( '#Prc' );
          desc10.putUnitDouble( id30, id31, amount );
          var id32 = charIDToTypeID( 'Rds ' );
          var id33 = charIDToTypeID( '#Pxl' );
          desc10.putUnitDouble( id32, id33, radius );
          var id34 = charIDToTypeID( 'Thsh' );
          desc10.putInteger( id34,threshold );
          try {
          executeAction( id29, desc10, DialogModes.ALL );
          catch (myError){
          do javascript myManualUnsharpScript with arguments {amount1, radius1, threshold1, amount2, radius2,
          threshold2}
          end tell
          end manualUnsharp
          • 2. Re: How to call javascript using applescript in InDesign cs2 Mac
            Ok - that's exactly what i was looking for. But I'm curious how do you get deal with things in double quotes in the javascript ie: ref1.putName(PSClass.Layer, "B&W conversion HSL Adjustments"); Because applescript freeks out when I try to compile.
            thanx.
            • 3. Re: How to call javascript using applescript in InDesign cs2 Mac
              Hi Andrew,
              Here is an example for you – a snippet from my script:
              global myBridgeLabel
              -- function that runs on clicking the button in adobe script studio project
              on clicked theObject
              if name of theObject is "b1" then
              set processName to "Started working"
              set myBridgeLabel to "Red"
              set myLabel to 1
              else if name of theObject is "b2" then
              set processName to "Started doing this"
              set myBridgeLabel to "Green"
              set myLabel to 2
              else if name of theObject is "b3" then
              set processName to "Started doing that"
              set myBridgeLabel to "Yellow"
              set myLabel to 3
              else if name of theObject is "b4" then
              set processName to "Finished doing this"
              set myBridgeLabel to "Blue"
              set myLabel to 4
              else if name of theObject is "b5" then
              set processName to "Finished doing that"
              set myBridgeLabel to "Purple"
              set myLabel to 5
              end if
              tell application "Adobe InDesign CS2"
              set mydocument to active document
              set myDocumentPath to full name of mydocument
              set workerName to "Kasyan"
              tell metadata preferences of mydocument
              set theDate to current date
              set myWeekday to weekday of theDate as string
              set myDenNedeli to my convertWeekday(myWeekday)
              set myRecord to (processName & " – " & workerName & " – ") & myDenNedeli & " " & text 1 thru -4 of time string of theDate & " \r"
              set myHistory to get property namespace "http://ns.adobe.com/photoshop/1.0/" path "History"
              set property namespace "http://ns.adobe.com/photoshop/1.0/" path "History" value myHistory & myRecord
              end tell
              set myJavaScript to "var myLabel =\"" & myBridgeLabel & "\"; app.activate(); var bt = new BridgeTalk; bt.target = \"bridge\"; myScript = 'app.displayDialogs = \"none\"; var t = new Thumbnail (File (\"" & myDocumentPath & "\")); var mdata = t.metadata; mdata.namespace = \"http://ns.adobe.com/xap/1.0/\"; mdata.Label = \"' + myLabel + '\";'; bt.body = myScript; bt.send();"
              do script myJavaScript language javascript
              In this javascript I use pares of single and double quotes.
              The main java script – myJavaScript – (inside double quotes) contains another java script – myScript – (inside single quotes) which runs in Bridge via BridgeTalk.
              I also put variables from AppleScript into JavaScript by using two pares of double quotes – the outside pare I escape with slashes:
              set myBridgeLabel to "Red" -- a variable I defined in AppleScript
              -- the contents of myBridgeLabel variable now becomes part of the JavaScript
              Kasyan
              • 4. Re: How to call javascript using applescript in InDesign cs2 Mac
                I'm wanting to execute a javascript from an applescript, but in an external file. Eg:
                do script "[pathToFile]/myScript.jsx"
                Is there a way to do this?
                Burr
                • 5. Re: How to call javascript using applescript in InDesign cs2 Mac
                  Hi Burr,
                  tell application "Adobe InDesign CS3"
                  set sScriptPath to "Macintosh HD:Applications:Adobe InDesign CS3:Scripts:Scripts Panel:YourJavaScript.jsx"
                  do script alias sScriptPath language javascript
                  end tell
                  Kasyan
                  • 7. Re: How to call javascript using applescript in InDesign cs2 Mac
                    Level 1
                    Actually, I haven't got it working. I'm getting an error:
                    Adobe InDesign CS3 got an error: Expected: ;
                    • 8. Re: How to call javascript using applescript in InDesign cs2 Mac
                      Level 1
                      You have to pass a file reference not the filepath as a string. Do script will attempt to execute a string as JavaScript -- which is what causes the "Expected: ;" error.
                      Dave
                      • 9. Re: How to call javascript using applescript in InDesign cs2 Mac
                        I tested my code again and made sure that it works. I suspect that the problem is caused by invalid path to the javascript file.
                        From ID scripting reference:
                        Method - do script
                        Parameter script alias or string
                        do script sScriptPath language javascript
                        These both lines work, I tested.
                        Kasyan
