2 Replies Latest reply on May 12, 2008 6:21 PM by
    [JS CS2] Drop Shadow
      How can I find out if an object on my page has a drop shadow or not via a script?
      Regards
      Norbert
        • 1. Re: [JS CS2] Drop Shadow
          A quick search in the help reveals this:
          b Class: DropShadowSetting
          Drop shadow settings.
          Element of ContentTransparencySetting.dropShadowSettings
          FillTransparencySetting.dropShadowSettings
          StrokeTransparencySetting.dropShadowSettings
          (a bit unexpected, but there you go.)
          FillTransparencySetting appears to be "Transparency settings for the fill applied to the parent object.", as a property of regular objects (Button, EPS, GraphicLine, Image, Rectangle, TextFrame etc.), although to be sure you should check StrokeTransparencySetting as well.
          • 2. Re: [JS CS2] Drop Shadow
            Hi Jongware,
            Sorry to be posting to this thread after such a long stretch og time but its related to this.
            In the Indesigns user interface I noticed that in the pages pallete, the page icon displays differently if it has a transparent object (It displays a gray chequered pattern).
            Is it possible to use this somehow via a script
            eg: If page icon display is chequered = page contains transparent objects
            else page does not contain transparent objects.
            Thanks in advance
            Norbert
