1 Reply Latest reply on Feb 18, 2008 2:06 PM by sstanleyau
    Print single plate Applescript
      The following script will turn off all plates (colors) except the one spot, open the print dialog, and the resulting .ps file will have only one spot color.
      However if I include "print without dialog" I get all plates.
      Any thoughts on why/how to avoid getting all plates
      tell application "Adobe InDesign CS3"
      tell active document
      tell print preferences
      -- set other properties for example, active printer style
      set color output to separations
      set printer to postscript file
      set PPD to "Xerox DocuColor 2006"
      set print file to "Chaco:Users:tpetrill:Desktop:TEST2.ps"
      end tell
      end tell
      set print ink of ink "Process Magenta" of document 1 to false
      set print ink of ink "Process Cyan" of document 1 to false
      set print ink of ink "Process Yellow" of document 1 to false
      set print ink of ink "Process Black" of document 1 to false
      -- set print ink of ink "RF.tp" of document 1 to true
      -- print without print dialog
      end tell
      set print ink of ink "Process magenta" of document 1 to true
      set print ink of ink "Process Cyan" of document 1 to true
      set print ink of ink "Process Yellow" of document 1 to true
      set print ink of ink "Process Black" of document 1 to true
      end tell
        • 1. Re: Print single plate Applescript
          sstanleyau Level 4
          On 19/2/08 2:09 AM, "Tom Petrillo" <member@adobeforums.com> wrote:<br /><br />> tell print preferences<br />> -- set other properties  for example, active printer style<br /><br />I don't see that you actually set an active printer preset. You probably<br />should, because it's possible that the preset last used to print from the<br />document contained settings incompatible with your ink settings (for<br />example, if it was printed to an inkjet or something similar).<br /><br />-- <br />Shane Stanley <sstanley@myriad-com.com.au>
