3 Replies Latest reply on Feb 21, 2008 9:23 AM by (Olav_Kvern)
    Execute an action through scripting
    Level 1
      Hi
      I would like to select a text frame which is associated with the root element from the body page and click the Untag button from the tags palette. Is it possible to automate it through scripting.
        • 1. Re: Execute an action through scripting
          Level 1
          Hi Priya1,
          How about:
          app.documents.item(0).xmlElements.item(0).untag();
          Ole
          • 2. Re: Execute an action through scripting
            Level 1
            Hi Ole
            i have tried the above one but it remove the complete structure the thing is my root element is associated with a text frame and i want to untag it.
            Manually i am able to do it by selecting the text frame and by clicking the Untag button from "Windows>Tags" palette. This when done deletes all the XML structure except the root element which is now not associated with any text frame but still exists.
            I would do these actions through scripting.
            • 3. Re: Execute an action through scripting
              Level 1
              Hi Priya,
              If the text frame is associated with the root, then you have other problems--really, the root should never be associated with a page item. Here's something that will untag the currently-selected frame:
              var myMenuAction = app.menuActions.item("Untag Frame");
              myMenuAction.invoke();
              Note, however, that invoking menu items is not a good way to work with scripting. This script will probably also fail in localized versions of InDesign--you'll have to mess with a translated key string (as described in the Scripting Guide) for it to work everywhere.
              Ole
