6 Replies Latest reply on Mar 5, 2008 4:59 PM by (Archie_Tucker)
    Defining & Deleting Colors using VBscript
      I would like to set several colors and if the color is already defined I want to delete it and re-define it. Below is how I'm defining a color.
      Archie
      Set Color = Document.Colors.Add
      Color.Name = "Green"
      Color.Model = idColorModel.idSpot
      Color.ColorValue = Array(100,0,100,0)
        • 1. Re: Defining & Deleting Colors using VBscript
          Level 1
          Hi Archie,
          Here's what I do:
          On Error Resume Next
          Set myColor = myDocument.Colors.Item("Green")
          If Err.Number <> 0 Then
          Set myColor = myDocument.Colors.Add
          Err.Clear
          End If
          On Error Goto 0
          Ole
          • 2. Re: Defining & Deleting Colors using VBscript
            Level 1
            Hi Ole,
            I had already found a piece of code like your example, but I need to delete the color if it's already there and then create it using my values. The deleting part is my problem.
            Archie
            • 3. Re: Defining & Deleting Colors using VBscript
              Level 1
              Hi Archie,
              Okay, how about this?
              If Err.Number = 0 Then
              myColor.Delete
              End If
              On Error Goto 0
              ...and then define your new color.
              Ole
              • 4. Re: Defining & Deleting Colors using VBscript
                Level 1
                That worked! But it has lead to another question. After the script is used to open a template, created the colors, create a dialog to enter a batch number (also file name), place the text, Save the document I then open it back up, but two of the colors that I defined are not there (LBlue & LGreen) all of the rest are there (Green, Purple, Orange, Red, Blue & Brown). Below is the complete script.
                Archie
                Rem N12 Script
                Rem SCRIPT INFO
                Rem -----------
                Rem Copyright Mindware Corporation Of America
                Rem Author: Archie O Tucker
                Rem Created: 03/03/08
                Rem Revised:
                Dim InDesign
                Set InDesign = CreateObject("InDesign.Application.CS3")
                Set Dialog = InDesign.Dialogs.Add
                Set FileSys = CreateObject("Scripting.FileSystemObject")
                Rem SET VALUES
                Rem ----------
                Dim MountSize
                Dim TemplateFolder
                MountLetter = "N"
                MountSize = "12"
                TextFolder = "E:\sxs\pm65\CA\"
                TemplateFolder = "E:\SXS\ID\"
                BatchFolder = "E:\SXS\ID\"
                Rem OPEN TEMPLATE
                Rem -------------
                Document = InDesign.Open(TemplateFolder+MountLetter+MountSize+".indt", True)
                Set Document =InDesign.ActiveDocument
                Rem DISPLAY DIALOG
                Rem --------------
                Dialog.Name = MountLetter + MountSize + " Autobatch "
                Set DialogColumn = Dialog.DialogColumns.Add
                set BorderPanel = DialogColumn.BorderPanels.Add
                set SubDialogColumn = BorderPanel.DialogColumns.Add
                Set BatchNumberLabel = SubDialogColumn.StaticTexts.Add
                BatchNumberLabel.StaticLabel = "Batch Number: "
                Set SubDialogColumn = BorderPanel.DialogColumns.Add
                Set BatchNumberField = SubDialogColumn.TextEditboxes.Add
                BatchNumberField.EditContents = "65926C"
                BatchNumberField.MinWidth = 100
                REM LINE:41
                Result = Dialog.Show
                If Result = True Then
                BatchNumber = BatchNumberField.EditContents
                DefineColor
                PlaceText
                SaveBatch
                CloseTemplate
                Dialog.Destroy
                Else
                Dialog.Destroy
                CloseTemplate
                End If
                Rem PLACE TEXT FUNCTION
                Rem -------------------
                Function PlaceText
                Set TextFrames = Document.TextFrames
                Set FirstFrame = TextFrames.Item(1)
                FirstFrame.Place (TextFolder + MountSize + "_" + BatchNumber + ".TXT")
                MsgBox "Ok:"
                End Function
                Rem SAVE BATCH FUNCTION
                Function SaveBatch
                InDesign.ActiveDocument.Save BatchFolder + BatchNumber + ".indd"
                End Function
                Rem CLOSE TEMPLATE FUNCTION
                Rem -----------------------
                Function CloseTemplate
                InDesign.ActiveDocument.Close
                End Function
                Rem DEFINE COLOR
                Rem ------------
                Function DefineColor
                Set Color = Document.Colors.Item("Green")
                If Error.Number = 0 Then
                Color.Delete
                End If
                Error.Clear
                Set Color = Document.Colors.Item("Purple")
                Set Color = Document.Colors.Delete
                End If
                Error.Clear
                Color.Name = "Purple"
                Color.ColorValue = Array(60,100,0,0)
                Set Color = Document.Colors.Item("Orange")
                Color.Delete
                End If
                Error.Clear
                Color.Name = "Orange"
                Color.ColorValue = Array(0,50,100,0)
                Set Color = Document.Colors.Item("Red")
                Color.Delete
                End If
                Error.Clear
                Color.Name = "Red"
                Color.ColorValue = Array(0,100,100,0)
                Set Color = Document.Colors.Item("Blue")
                Color.Delete
                End If
                Error.Clear
                Color.Name = "Blue"
                Color.ColorValue = Array(100,100,0,0)
                Set Color = Document.Colors.Item("LBlue")
                Color.Delete
                End If
                Error.Clear
                Color.Name = "LBlue"
                Color.ColorValue = Array(76,9,0,0)
                Set Color = Document.Colors.Item("LGreen")
                Color.Delete
                End If
                Error.Clear
                Color.Name = "LGreen"
                Color.ColorValue = Array(60,0,79,0)
                Set Color = Document.Colors.Item("Brown")
                Color.Delete
                End If
                Error.Clear
                Color.Name = "Brown"
                Color.ColorValue = Array(68,70,88,0)
                End Function
                • 5. Re: Defining & Deleting Colors using VBscript
                  Level 1
                  Hi Archie,
                  A couple of things:
                  You need to pass object references in to the functions to get them to work reliably.
                  You might want to name your variables something other than the class names--just to avoid confusion.
                  Try something like this:
                  Rem N12 Script
                  Rem SCRIPT INFO
                  Rem -----------
                  Rem Revised:
                  Dim myInDesign
                  Set myInDesign = CreateObject("InDesign.Application.CS3")
                  Set myDialog = myInDesign.Dialogs.Add
                  Rem SET VALUES
                  Rem ----------
                  MountLetter = "N"
                  MountSize = "12"
                  Rem OPEN TEMPLATE
                  Rem -------------
                  Set myDocument = myInDesign.Open(TemplateFolder+MountLetter+MountSize+".indt", True)
                  Rem DISPLAY DIALOG
                  Rem --------------
                  myDialog.Name = MountLetter + MountSize + " Autobatch "
                  Set myDialogColumn = myDialog.DialogColumns.Add
                  Set myBorderPanel = myDialogColumn.BorderPanels.Add
                  Set mySubDialogColumn = myBorderPanel.DialogColumns.Add
                  Set myBatchNumberLabel = mySubDialogColumn.StaticTexts.Add
                  myBatchNumberLabel.StaticLabel = "Batch Number: "
                  Set myBatchNumberField = mySubDialogColumn.TextEditboxes.Add
                  myBatchNumberField.EditContents = "65926C"
                  myBatchNumberField.MinWidth = 100
                  Rem LINE:41
                  myResult = myDialog.Show
                  If myResult = True Then
                  myBatchNumber = myBatchNumberField.EditContents
                  myDefineColor myDocument
                  myPlaceText myDocument, myTextFolder, myMountSize, myBatchNumber
                  mySaveBatch myInDesign, myBatchFolder, myBatchNumber
                  myCloseTemplate myInDesign
                  myDialog.Destroy
                  Else
                  myDialog.Destroy
                  End If
                  Function myPlaceText(myDocument, myTextFolder, myMountSize, myBatchNumber)
                  Set myTextFrames = myDocument.TextFrames
                  Set myFirstFrame = myTextFrames.Item(1)
                  myFirstFrame.Place (TextFolder + MountSize + "_" + BatchNumber + ".TXT")
                  MsgBox "Ok:"
                  End Function
                  Function mySaveBatch(myInDesign, myBatchFolder, myBatchNumber)
                  myInDesign.ActiveDocument.Save BatchFolder + BatchNumber + ".indd"
                  End Function
                  Function myCloseTemplate(myInDesign)
                  myInDesign.ActiveDocument.Close
                  End Function
                  Rem DEFINE COLORS
                  Rem ------------
                  Function myDefineColors(myDocument)
                  myDefineColor myDocument, "Green", idColorModel.idSpot, Array(100, 0, 100, 0)
                  myDefineColor myDocument, "Purple", idColorModel.idSpot, Array(60, 100, 0, 0)
                  myDefineColor myDocument, "Orange", idColorModel.idSpot, Array(0, 50, 100, 0)
                  myDefineColor myDocument, "Red", idColorModel.idSpot, Array(0, 100, 100, 0)
                  myDefineColor myDocument, "Blue", idColorModel.idSpot, Array(100, 100, 0, 0)
                  myDefineColor myDocument, "LBlue", idColorModel.idSpot, Array(76, 9, 0, 0)
                  myDefineColor myDocument, "LGreen", idColorModel.idSpot, Array(60, 0, 79, 0)
                  myDefineColor myDocument, "Brown", idColorModel.idSpot, Array(68, 70, 88, 0)
                  End Function
                  Rem DEFINE COLOR
                  Rem ------------
                  Function myDefineColor(myDocument, myColorName, myColorModel, myColorValue)
                  Set myColor = myDocument.Colors.Item(myColorName)
                  If Error.Number > 0 Then
                  myColor.Name = myColorName
                  Error.Clear
                  End If
                  On Error GoTo 0
                  myColor.Model = myColorModel
                  myColor.ColorValue = myColorValue
                  End Function
                  Ole
                  • 6. Re: Defining & Deleting Colors using VBscript
                    Level 1
                    Hi Ole,
                    Thank you for your help, I now have that part working. I think I recognize your name from a seminar I went to a very long time ago concerning Aldus PageMaker. I think it was in Seattle. I have been using PageMaker's tagged text and scripting for awhile and now I'm working on moving customers to InDesign.
                    Archie
