6 Replies Latest reply on Aug 11, 2008 12:34 AM by (scriptworx)
    [JS] [CS3]  Triggering a script
      Hi all
      I am looking to find the best way to trigger a script in InDesign. In the past i have used an applescript to monitor a folder, and when something appears in the folder a doScript will trigger the required script.
      I am guessing there is a more efficient way just using JS. My intentions are ultimately to be using IDServer, linked to my companies web site. What I know I can do is create .csv files on the server from actions on the web site. This CSV file will hold the data I need to use in the ID environment.
      I know this is very vague, but at the moment I have no solid plans, but want to make sure something can be done. I cannot use AS as the environment for the IDServer will be a Windows server.
      Any pointers will be cool.
      Cheers
      Roy
        • 1. Re: [JS] [CS3]  Triggering a script
          Kasyan Servetsky Level 5
          Hi Roy,
          I dont know if its possible to monitor a folder in JS, but I did it using timer object in Visual Basic. It is quite easy: you can set an interval property in milliseconds for the timer to trigger a function that does what you want.
          Kasyan
          • 2. [JS] [CS3] Triggering a script
            Level 1
            Similarly, you can use the $.sleep() function in a loop to get a similar result.
            -X
            for photoshop scripting solutions of all sorts
            contact: xbytor@gmail.com
            • 3. Re: [JS] [CS3]  Triggering a script
              xbytor,
              Can you give a little more explanation about creating a hotfolder with
              the VB timer object?
              Thanks in advance
              Michel
              • 4. [JS] [CS3] Triggering a script
                Level 1
                I don't know if you can do this in VBScript - but in VB6 IDE you need to add:
                - Timer control to Form and set interval
                - Folder control and set folder you want to monitor
                in Timer's body function you need to check for new files in folder - if you move/delete files after processing - it's piece of cake ;) just process first file from list until files count > 0 ;)
                but if you leave files in watched folder - you need to store somewhere info about files already processed and check if file was processed before you do something with it
                robin
                www.adobescripts.com
                • 5. Re: [JS] [CS3]  Triggering a script
                  Hi Michel,
                  To provide an example, here is a simple program, which monitors a hot folder: every 5000 milliseconds (Interval property of the Timer) it counts files with pdf extension, makes simple calculations and shows statistics.
                  Kasyan
                  Dim myPagesMax As Integer
                  Dim myPagesRekl As Integer
                  Dim myTop As Single
                  Dim myLeft As Single
                  Dim myFolderName As String
                  Private Sub Command1_Click()
                  Timer1.Enabled = True
                  Command1.Enabled = False
                  Command2.Enabled = True
                  Command3.Enabled = False
                  End Sub
                  Private Function CountFiles() As Integer
                  Set fsoRef = CreateObject("Scripting.FileSystemObject")
                  If Not fsoRef.FolderExists(myFolderName) Then
                  MsgBox ("Ïàïêà " & myFolderName & " íå ñóùåñòâóåò!"), vbCritical, "Îøèáêà"
                  Timer1.Enabled = False
                  Command1.Enabled = True
                  Command2.Enabled = False
                  CountFiles = 0
                  Exit Function
                  Unload Me
                  Else
                  Set folderRef = fsoRef.GetFolder(myFolderName)
                  i = 0
                  For Each f In folderRef.Files
                  If UCase(Right(f.Name, 4)) = ".PDF" Then
                  i = i + 1
                  End If
                  Next
                  CountFiles = i
                  End If
                  End Function
                  Private Sub Command2_Click()
                  Command3.Enabled = True
                  Label1.Caption = ""
                  Label4.Caption = ""
                  Label6.Caption = ""
                  Label12.Caption = ""
                  ProgressBar1.Value = 0
                  End Sub
                  Private Sub Command3_Click()
                  myFolderName = InputBox("Ââåäèòå ïóòü ê ïàïêå äëÿ PDF ôàéëîâ òåêóùåãî íîìåðà", "Âûáîð ïàïêè", myFolderName)
                  If myFolderName = "" Then Exit Sub ' leaves sub if the variable i is null
                  Form1.Caption = CurrentIssue
                  End Sub
                  Private Sub Form_Load()
                  myTop = GetSetting("PdfCounter", "Settings", "Top", 0)
                  myLeft = GetSetting("PdfCounter", "Settings", "Left", 0)
                  myPagesMax = GetSetting("PdfCounter", "Settings", "PagesMax", 160)
                  myPagesRekl = GetSetting("PdfCounter", "Settings", "PagesRekl", 50)
                  myFolderName = GetSetting("PdfCounter", "Settings", "FolderName", "K:\PS\801\Original")
                  Form1.Top = myTop
                  Form1.Left = myLeft
                  Text1.Text = myPagesMax
                  Text2.Text = myPagesRekl
                  mySplit = Split(myFolderName, "\")
                  myCurIssue = mySplit(2)
                  Form1.Caption = myCurIssue
                  End Sub
                  Private Sub Form_Unload(Cancel As Integer)
                  myTop = Form1.Top
                  myLeft = Form1.Left
                  SaveSetting "PdfCounter", "Settings", "Top", myTop
                  SaveSetting "PdfCounter", "Settings", "Left", myLeft
                  SaveSetting "PdfCounter", "Settings", "PagesMax", myPagesMax
                  SaveSetting "PdfCounter", "Settings", "PagesRekl", myPagesRekl
                  SaveSetting "PdfCounter", "Settings", "FolderName", myFolderName
                  End Sub
                  Private Sub Text1_Change()
                  myPagesMax = CInt(Val(Text1.Text))
                  End Sub
                  Private Sub Text2_Change()
                  myPagesRekl = CInt(Val(Text2.Text))
                  End Sub
                  Private Sub Timer1_Timer()
                  If Not CountFiles = 0 Then
                  Label1.Caption = CountFiles
                  myPagesOur = myPagesMax - myPagesRekl
                  If Not myPagesOur = 0 Then
                  myOnePercent = 100 / myPagesOur
                  End If
                  myPagesCur = CountFiles
                  myPagesLeft = myPagesOur - myPagesCur
                  myCurPercent = CountFiles * myOnePercent
                  Label4.Caption = CInt(myCurPercent)
                  Label6.Caption = myPagesLeft
                  Label12.Caption = myPagesOur
                  If myCurPercent > 100 Then
                  myCurPercent = 100
                  End If
                  ProgressBar1.Visible = True
                  ProgressBar1.Min = 0
                  ProgressBar1.Max = 100
                  ProgressBar1.Value = myCurPercent
                  Else
                  Label1.Caption = 0
                  End If
                  myPagesCur = 0
                  myCurPercent = 0
                  Label4.Caption = 0
                  Label6.Caption = myPagesOur
                  End If
                  End Sub
                  Private Function CurrentIssue() As String
                  If Not myFolderName = "" Then
                  If Val(Mid(myFolderName, 7, 3)) > 0 Then
                  CurrentIssue = "Òåêóùèé íîìåð: " & Val(Mid(myFolderName, 7, 3))
                  Else: CurrentIssue = "Òåêóùèé íîìåð íå âûáðàí."
                  End If
                  Else
                  End If
                  End Function
                  • 6. Re: [JS] [CS3]  Triggering a script
                    Level 1
                    Kasyan,
                    Thanks for your posting, but this is Visual Basic I think.
                    What I need is a vbscript solution.
                    I think I found something very simple like this that does the job:
                    Set objShell = CreateObject("Wscript.Shell")
                    strComputer = "."
                    Set objWMIService = GetObject("winmgmts:\\" & strComputer & "\root\cimv2")
                    Do
                    Set colFileList = objWMIService.ExecQuery _
                    ("ASSOCIATORS OF {Win32_Directory.Name='C:\scripts'} Where " _
                    & "ResultClass = CIM_DataFile")
                    If colFileList.Count >= 1 Then
                    objShell.Run("C:\indesign\triggerdoc.indd")
                    Wscript.Sleep 15000
                    End If
                    Loop
                    Michel
