3 Replies Latest reply on Mar 18, 2008 4:51 AM by (hp_)
    place xml in anchored textframe
      hi all,
      i'm using IDCS3 and javascript. i tried to place a xmlElement into an anchored textFrame and got the error:
      "Elements cannot be place into an inline."
      code is (shortened):
      ] _anchoredFrame = _xmlEbene0.xmlElements.item(_refElement).xmlElements[i].insertionPoints.item(0).textFrame s.add();
      ] _xmlElement.placeXML(_anchoredFrame);
      anyway i can place the element into a ordinary textFrame and cut/paste this frame into the inline frame.
      seems like a pretty dirty workaround. questions arise:
      1. am i missing something?
      2. wherre is the problem in inserting xml into inline textFrames?
      3. is my workaround a bug or feature -> is indesign likely to crash with such documents? is there any problem with xml handling further on?
      thanks for any information,
      gregor
        • 1. Re: place xml in anchored textframe
          Level 1
          hi all,
          some additionally information about the outcomes of the script:
          with the above workaround (cut/paste) inDesign messes the xml up.
          the original placed (and cutted) xmlElement is now inserted as a xmlElement "Story" inserted at the anchored position in the xml tree.
          this is of course not intended (but easy fixed with renaming)
          by the way: this seems to affect any cut/paste operation with xmlElements. in my opinion this is sort of bug in inDesign xml handling.
          cheers,
          gregor
          • 2. Re: place xml in anchored textframe
            srakete Level 1
            Hi Gregor,
            I have done something similar with Xml Rules. The method I used was placeIntoInlineFrame:
            function processElement(){
            this.name = "processElement";
            this.xpath = "//root/myElement";
            this.apply = function(myElement, myRuleProcessor){
            var myTextframe = myElement.placeIntoInlineFrame([25,2.78])
            myTextframe.fit(FitOptions.FRAME_TO_CONTENT);
            myTextframe.anchoredObjectSettings.anchoredPosition = AnchorPosition.ANCHORED;
            myTextframe.anchoredObjectSettings.anchorPoint = AnchorPoint.BOTTOM_RIGHT_ANCHOR;
            myTextframe.anchoredObjectSettings.horizontalAlignment = HorizontalAlignment.RIGHT_ALIGN;
            myTextframe.anchoredObjectSettings.horizontalReferencePoint = AnchoredRelativeTo.TEXT_FRAME;
            return false;
            Hope this helps
            Stefan
            http://www.indesignscript.de
            • 3. Re: place xml in anchored textframe
              Level 1
              hi stefan,
              cool this works - just got the proof of concept working. i hadn't thougt to realize such an operation with xmlRules.
              there's nothing to add to the above rule!
              thanks a lot.
              grüße,
              gregor
